Setup wholesale VoIP
Mohammed Hasaballa
Greeting,
I am trying to help a friend who needs to setup a wholesale VoIP between US and Egypt
curretnly budget only allow for Cisco2600XM and need to support E1 voice
i am not sure which module to use!
VWIC-2MFT-E1 OR
NM-HDV-1E1-30E
is the only difference the onboard DSP for the NM Vs no DSP on the 3MFT cause the 2600xm doesn't have any slot for DSPs
also, what to use for billing?
your help is greatly appericated
frlindse
Hi Mohammed,
THe NM-HDV-1E1-30E would be OK for one circuit, but will require another card for a second.  You can use the CDR function for billing info
http://www.cisco.com/en/US/partner/tech/tk1077/technologies_tech_note09186a0080094e72.shtml
Frank
2600XM are end of life product and you will not be able to purchase it from Cisco.  I would suggest you low end ISR G2 for VOIP.
http://www.cisco.com/en/US/prod/collateral/routers/ps259/prod_end-of-life_notice0900aecd804446da.html
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
