Sign the Self-signed certificate of cisco by 3ed party CA
linuxchild
Hello
I would like to know if any one has signed the self-signed certificate of cisco by 3ed party CA
I just need a sumary of the seteps to be done , my final goal is to have my phones use a certificate that is signed by my client CA (3ed party)  for call signaling and communication encryption
rhugo
Level 3
Level 3
You will run through a process of using Cisco Unified OS to generate CSRs for he 3rd party certs, then, its just a matter of utilizing the CAPF feature for the phones and uploading the 3rd party certs using the CTL client plugin.  Here is a good detailed doc, describing the process and configuration steps:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_5_1/secugd/secuview.html#wp1129377
Thank you for your answer , but the link you gave me does not say to which certificate I have to make the CSR (callmanager, capf , callmanager trust , there are more than 30 certidficate )
and when importing it , do I have to import it as capf , capf-trust , callmanager  or callmanager-trust
this is what I'm searching to know
thank you again for your help
