I would like feedback and settings Help for AT&T wireless cell phone number via Single number reach mobility in VoIP. The default timer settings aren't working correctly and tweaks have failed to produce results.
Remote destination specific Timer Information is 3 seconds before ringing this phone when my business line is dialed
The same setting work if remote destination is a Verizon Wireless number.
You're solution would be appreciated. The problem is the AT&T cell phone can answer but then the caller will hear no audio and then after 15 seconds music on hold will play.
