09-11-2012 05:57 PM - edited 03-16-2019 01:09 PM
I believe the answer is no, but looking to definitive verification – a single Presence server cannot provide this service for multiple clusters, can it? Meaning, the customer is wanting to avoid having to stand up a Presence server in each of four clusters. (No cross-cluster presence is required – just the ability to “register” the Presence server to multiple CMs.)
Again, pretty sure the answer is no – furthered by the fact that Presence will now be rolled directly into CM w/ 9.0.
Thx
Solved! Go to Solution.
09-12-2012 06:44 AM
You're correct, the answer is NO.
The relationship between CUCM - CUPS/IM&P is 1:1
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-12-2012 06:44 AM
java
