SIP/2.0 503 Service Unavailable
sindan
This is the message i receive from an Adtran box that has a SIP trunk with a CUCM 7.1(3). Behind the Adtran i am trying to place a call:
TA904#
TA904#debug isdn l2-formatted
TA904#debug sip stack message
TA904#
TA904#
TA904#
TA904#
18:56:56 ISDN.L2_FMT PRI  1  ===================================================
18:56:56 ISDN.L2_FMT PRI  1  Recd = Sapi:00  C/R:R Tei:00
18:56:56 ISDN.L2_FMT PRI  1         Ctl:INFO     Ns:25   Nr:26
18:56:56 ISDN.L2_FMT PRI  1         Prot:08  CRL:2  CRV:000C
18:56:56 ISDN.L2_FMT PRI  1         M - 05 SETUP
18:56:56 ISDN.L2_FMT PRI  1          IE - 04 BEARER CAPABILITY   Len=3
18:56:56 ISDN.L2_FMT PRI  1               80 Xfer Cap.:SPEECH
18:56:56 ISDN.L2_FMT PRI  1               90 Xfer Rate:64k
18:56:56 ISDN.L2_FMT PRI  1               A2 Layer 1:u-Law
18:56:56 ISDN.L2_FMT PRI  1          IE - 18 CHANNEL ID          Len=3
18:56:56 ISDN.L2_FMT PRI  1               A9 Primary Rate
18:56:56 ISDN.L2_FMT PRI  1                  Intfc ID:IMPLICIT
18:56:56 ISDN.L2_FMT PRI  1                  Pref/Excl:EXCLUSIVE
18:56:56 ISDN.L2_FMT PRI  1                  D-Chan Indicated:NO
18:56:56 ISDN.L2_FMT PRI  1                  Chan. Sel:FOLLOWS
18:56:56 ISDN.L2_FMT PRI  1               83 Numb/Map:NUMBER
18:56:56 ISDN.L2_FMT PRI  1               97 Channel:23
18:56:56 ISDN.L2_FMT PRI  1          IE - 70 CALLED PARTY #      Len=12
18:56:56 ISDN.L2_FMT PRI  1               A1 Numb. Type:NATIONAL
18:56:56 ISDN.L2_FMT PRI  1                  Numb. Plan:ISDN/Telephony
18:56:56 ISDN.L2_FMT PRI  1                  Ph.# 12014075167
18:56:56 ISDN.L2_FMT PRI  1  Sent = Sapi:00  C/R:C Tei:00
18:56:56 ISDN.L2_FMT PRI  1         Ctl:INFO     Ns:26   Nr:26
18:56:56 ISDN.L2_FMT PRI  1         Prot:08  CRL:2  CRV:800C
18:56:56 ISDN.L2_FMT PRI  1         M - 02 CALL_PROC
18:56:56 SIP.STACK MSG     Tx: UDP src=10.230.253.222:5060 dst=10.100.253.100:50
60
18:56:56 SIP.STACK MSG         INVITE sip:12014075167@10.100.253.100:5060 SIP/2.
18:56:56 SIP.STACK MSG         From: <sip:9735971115@10.230.253.222:5060;transpo
rt=UDP>;tag=23c8750-0-13c4-147a-205a104a-147a
18:56:56 SIP.STACK MSG         To: <sip:12014075167@10.100.253.100:5060>
18:56:56 SIP.STACK MSG         Call-ID: 23edc68-0-13c4-147a-a6f918e-147a@10.230.
253.222
18:56:56 SIP.STACK MSG         CSeq: 1 INVITE
18:56:56 SIP.STACK MSG         Via: SIP/2.0/UDP 10.230.253.222:5060;branch=z9hG4
bK-147a-4fff76-57909b84
18:56:56 SIP.STACK MSG         Max-Forwards: 70
18:56:56 SIP.STACK MSG         Supported: 100rel,replaces
18:56:56 SIP.STACK MSG         Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OP
TIONS, PRACK, REFER, REGISTER
18:56:56 SIP.STACK MSG         User-Agent: ADTRAN_Total_Access_904_2nd_Gen/A2.06
.00.E
18:56:56 SIP.STACK MSG         Contact: <sip:9735971115@10.230.253.222:5060;tran
sport=UDP>
18:56:56 SIP.STACK MSG         Content-Type: application/SDP
18:56:56 SIP.STACK MSG         Content-Length: 268
18:56:56 SIP.STACK MSG         v=0
18:56:56 SIP.STACK MSG         o=- 1218135416 1218135416 IN IP4 10.230.253.222
18:56:56 SIP.STACK MSG         s=-
18:56:56 SIP.STACK MSG         c=IN IP4 10.230.253.222
18:56:56 SIP.STACK MSG         t=0 0
18:56:56 SIP.STACK MSG         m=audio 10000 RTP/AVP 0 18 101
18:56:56 SIP.STACK MSG         a=rtpmap:0 PCMU/8000
18:56:56 SIP.STACK MSG         a=rtpmap:18 G729/8000
18:56:56 SIP.STACK MSG         a=fmtp:18 annexb=no
18:56:56 SIP.STACK MSG         a=silenceSupp:off - - - -
18:56:56 SIP.STACK MSG         a=rtpmap:101 telephone-event/8000
18:56:56 SIP.STACK MSG         a=fmtp:101 0-15
18:56:56 SIP.STACK MSG     Rx: UDP src=10.100.253.100:5060 dst=10.230.253.222:50
60
18:56:56 SIP.STACK MSG         SIP/2.0 100 Trying
18:56:56 SIP.STACK MSG         Date: Fri, 13 May 2011 20:42:12 GMT
18:56:56 SIP.STACK MSG         Allow-Events: presence
18:56:56 SIP.STACK MSG         Content-Length: 0
253.222
60
18:56:56 SIP.STACK MSG         SIP/2.0 503 Service Unavailable
18:56:56 SIP.STACK MSG         Warning: 399 TEXAS "Unable to find a device handl
er for the request received on port 5060 from 10.230.253.222"
18:56:56 SIP.STACK MSG         To: <sip:12014075167@10.100.253.100:5060>;tag=161
441024
253.222
60
18:56:56 SIP.STACK MSG         ACK sip:12014075167@10.100.253.100:5060;transport
=UDP SIP/2.0
441024
253.222
18:56:56 SIP.STACK MSG         CSeq: 1 ACK
.00.E
sport=UDP>
18:56:56 ISDN.L2_FMT PRI  1         Ctl:INFO     Ns:27   Nr:26
18:56:56 ISDN.L2_FMT PRI  1         M - 45 DISCONNECT
18:56:56 ISDN.L2_FMT PRI  1          IE - 08 CAUSE               Len=2
18:56:56 ISDN.L2_FMT PRI  1               82 Location:LN
18:56:56 ISDN.L2_FMT PRI  1               A9 Cause:41 (TEMPORARY_FAILURE)
18:56:57 ISDN.L2_FMT PRI  1  ===================================================
18:56:57 ISDN.L2_FMT PRI  1  Recd = Sapi:00  C/R:R Tei:00
18:56:57 ISDN.L2_FMT PRI  1         Ctl:INFO     Ns:26   Nr:28
18:56:57 ISDN.L2_FMT PRI  1         Prot:08  CRL:2  CRV:000C
18:56:57 ISDN.L2_FMT PRI  1         M - 4D RELEASE
18:56:57 ISDN.L2_FMT PRI  1  Sent = Sapi:00  C/R:C Tei:00
18:56:57 ISDN.L2_FMT PRI  1         Ctl:INFO     Ns:28   Nr:27
18:56:57 ISDN.L2_FMT PRI  1         Prot:08  CRL:2  CRV:800C
18:56:57 ISD_FMT PRI  1         M - 5A RELEASE_CMP
I  think the question is how would the CUCM know how to route the call caming through the SIP trunk.
The trunk at the bottom is the one in discussion.
mudmathu
Hi Sindan,
looking at the debugs it seems that the CUCM does not know where to route the call and thus you are getting this error.
Can you please provide me the call flow so that we can check where to route the calls, example ::
Service Provider -> PRI -> G/w ->  SIP -> CUCM -> ??
Also can you make a test call and run the debug "debug ccsip messages" and provide the output.
Mudit
Found that the CCM server in the CCM group in the Device Pool was listed as a secondary. Rearanging them fixed the problem.
