SIP and TripleCombo
Hi guys
I collect 218MB of traces about SIP
Enable SIP Keep Alive
  Enable SIP Call Processing Trace
  Enable SIP Stack Trace
I put files in TripleCombo (lastest version) and nothing is showed. Can you help me?
Is there another trace reader of sip calls for CUCM?
cchagnon
What version of cucm did you pull the traces from?
What is the version of triple combo your using?
I have seen the latest version of triple combo have issues with cucm version 7 and before. The new version made some changes to allow cucm version 8.
If you can let me know the versions i can check into it
thanks
Hi Craig
Thank you for your reply.
I found the problem. The triplecombo read just files ccm*.txt. I was input the sdl*.txt
thanks again
