Sip Call failure
Suchi
Below is my voice setup,
CUCM----CUBE---SIP Trunk---ITSP
I can make inbound & outbound calls without any issue except one external party. When I make a call to that particular number, end device rings & disconnect when other end user pick up the call. But incoming calls from this number is working fine.  When I check logs, it indicates codec issue.
CSeq: 102 BYE
Reason: Q.850;cause=47
Content-Length: 0
Do i need different config/dail peer for this number?
Suchira
Vivek Batra
Can you please share the ouput of debug ccsip messages of failed call...
- Vivek
also share the dial-peer configuration & debug voice ccapi inout along with debug ccsip message as Vivek asked for the failed call please.
//Suresh Please rate all the useful posts.
