SIP call loops between dial-peers
d-domjahn
Hi there,
we have CUCM7 "talking" to a CUBE router via SIP trunk; CUBE terminates SIP calls from a Telco:
CUCM --- CUBE --- SIP Provider
Calls to known extensions are handled fine whereas calls to unknown extensions loop between the dial-peers
for incoming and outgoing calls:
the relevant configuration is:
voice service voip
address-hiding
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
sip
  header-passing error-passthru
  no update-callerid
  midcall-signaling passthru
  privacy-policy passthru
  g729 annexb-all
dial-peer voice 100 voip
description *** Incoming SIP provider
destination-pattern 012345.%  <-- our phone number with DID/extensions
session protocol sipv2
session target ipv4:<IP-Address-of-CUCM>
incoming called-number 012345.%  <-- this entry has to be specified otherwise dial-peer isn't matched
        for incoming calls
voice-class sip asserted-id pai
voice-class sip privacy-policy passthru
dial-peer voice 200 voip
description *** Outgoing to SIP Provider
destination-pattern .T
session target dns:<IP of SIP Provider>
voice-class sip early-offer forced
voice-class sip profiles 1
Problem: incoming call to unknown extension is catched by DP 100 but denied by CUCM causing CUBE to
route this call out to DP 200 (causing the SIP Provider to "reflect" the call back --> loop).
Is there an option to disable this kind of "hairpinning"?
Thank you in advance,
David
neharris
Were you able to correct the problem?  If so how?
I'm seeing this too.  I don't think carrier thought about cases where NPA starts with a "9" and the NXX starts with a "9" (my case)
unfortunately not yet - hope someone could help.
The easiest way to stop this sort of thing is usually to ensure that your number plan is not ambiguous - e.g. if you dial 9 to route externally, allow CCM to send the 9 out with the number.
On your gateway, only one dial-peer pointing out to the SP would match the leading 9, and you would then strip that out with a translation pattern (as it's not a POTS peer this won't happen automagically).
Your inbound-to-CCM peer should then match non 9 numbers.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
hi Aaron,
thanks for the hint - I'll give it a try.
David
