SIP Phone 9951 multi-line with CME cannot received 2nd rang line.
tanan.ead1
Level 2
Level 2
Hi All,
        I have problem with 9951 phone, when we receive multiple calls at a time, i try to pick up the 2nd line but it always answering the 1st line which was ringing first. i even press the 2nd line but it still picks up the 1st line. please help me to fixed this problem, i don't understand why even if i manually choose the correct line it still picks up whichever line rang first.
Configuration as below
voice register pool 40
id mac 0123.4567.890a
type 9951
number 1 dn 1
number 2 dn 2
number 3 dn 3
number 4 dn 4
dtmf-relay rtp-nte
voice-class codec 1
username TestAAA password 12345
voice register dn 1
number 100
call-forward b2bua busy 300
call-forward b2bua noan 300 timeout 20
allow watch
name Test ABC
shared-line max-calls 10
label 2222222 ext 100
mwi
voice register dn 2
number 101
allow watch
name Test XYZ
label 2222222 ext 101
mwi
voice register pool-type 8851
xml-config maxNumCalls 6
xml-config busyTrigger 2
num-lines 100
addons 2
description Cisco IP Phone 8851
reference-pooltype 9951
Thanks.
Dennis Mink
you have 4 lines on that phone, if you dial 100 on dn1 and then have someone else dial 100 again, it will ring dn1 again,  that is as expected. you cnt pick up a call on 100 from dn 101.
Please remember to rate useful posts, by clicking on the stars below.
when two line ring simultaneously with different dn (100 and 101) i cannot receive the 101 even if i push the 101 line button, this call from 100 takeover this call anytime.  because 100 line rang first.
