SIP Profile question - invalid incoming caller ID number change to private for outbound calls
hmalekib
Hi guys,
I'm trying to have our router setup so any calling going through it outgoing if the caller ID number is not correct (10 digits) it displayed private/anonymous.
Here is what I've done, I created a rule to change any caller ID that's not in correct format to 0000000000.
Now I need to create a sip profile so all calls with caller ID 0000000000 is going out private/anonymous.
Here is my config:
voice translation-rule 20
rule 1 /^\([2-9]..[2-9]......$\)/ /\1/
rule 2 /^1\([2-9]..[2-9]......$\)/ /\1/
rule 3 /^.*\([2-9]..[2-9]......$\)/ /\1/
rule 4 /^.*\(\)/ /0000000000\1/
dial-peer voice 2 voip
description Incoming call leg - Outbound calls
translation-profile incoming 20
preference 1
incoming called-number #.T
dtmf-relay rtp-nte
codec transparent
fax-relay ecm disable
fax-relay sg3-to-g3
fax rate 14400
fax nsf 000000
fax protocol t38 version 3 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
Any suggestions will be appreciated.
Hi @hmalekib
 take a look at the Number Translation using Voice Translation Profile link.
 You can use the following commands (as an example):
voice translation-rule 3
 rule 1 /123/ /456/
voice translation-profile profile1
 translate calling 3
dial-peer voice 10 voip
 translation-profile incoming profile1
Hope this helps,
 Marcelo Morais
Hi Marcelo
I was able to change the number to 0000000000 now I need to restrict the caller ID using SIP profiles.
Any idea how to do that?
