IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5954 Views
  • 14 replies
Hi all, A customers is going to upgrade a cucm environment consisting of 2 servers (Pub/Sub)From 11.0 to 11.5As you all know you have to start upgrading  with the Pub, after that you can choose whether you want to switch version or not.Its mandatory ...
monasir by Level 1
  • 1032 Views
  • 4 replies
In CUCM 10, any idea why this shows up on the user web page when I look at the ring settings for my phone?  "Ring Settings has been deactivated by your administrator"  I'd like to allow users to change their ring settings, but it says that option has...
voip7372 by Level 4
  • 2841 Views
  • 2 replies
Hi all,i need to change some settings on a voice gateway registered to cucm , the VGW has 16 pri connected to it and receiving calls 24/7 obviusly no all the pri are full all the time or busy but during the whole day there are some active calls on it...
Resolved! From SCCP to SIP
Hi GuysI want to change our 7960G phones from SCCP to SIP have donwloaded all the required files and uploaded to the router 2821The debug commands show the phone asking for the files but router responding with no such file found, why is this happenin...
Hi All, Does anyone knows if version 12.6 resolved the failover issue with Expressway , prior to version 12.x , version 11.9 document stated clearly that it is not supported but now on this version 12.6 , I do not find this note !! , does this mean t...
Zoltar by Level 1
  • 272 Views
  • 0 replies
Resolved! Inter-CUCM Calling
I am trying to call between two phones registered in two different CUCMs . I am trying to configure SIP trunk between  the two CUCM, but the SIP status shows unknown -options ping not enabled. I followed steps to enabe options ping for sip profile, b...
AMB14 by Cisco Employee
  • 1122 Views
  • 3 replies
I note that the Cisco documentation states the following:"A single Unified CM Subscriber supports a maximum of 100 hunt pilots with call queuing enabled per node" This raises a few questions in my mind:1: I'm reading "node" in this context as "subscr...
imellor by Level 1
  • 344 Views
  • 0 replies
