11-08-2011 06:03 AM - edited 03-16-2019 07:56 AM
My Sip account is perfectly registered with the Sip provider, but the problem is that the router every time tried to registered another account (line 120) and the provider block the account.
How can I do for block this issue?
I've attached the configuration
This is the show sip-ua
cisco2901#show sip-ua register status
Line peer expires(sec) registered P-Associated-URI
120 40003 128 no
60510988031 -1 2100 yes
11-10-2011 07:20 AM
Hello.
You can stop the router trying to register the ephone:
voice register dn 4
number 120 no-reg primary
11-10-2011 09:25 AM
Ok, I needed also to reload the router (I don't know why but after that everythings work fine)
11-10-2011 02:38 PM
OK good. I suspect the registration would have disappeared after expiry (marked as 128 seconds in your example above)
