02-25-2013 10:32 AM - edited 03-16-2019 03:55 PM
I'm trying to register a 7945 SIP phone in SRST to a 2921 gateway but can't get it to work. I have the SRST reference assigned in CUCM and when I span the switchport that my voice gateway is connected to I can see the 7945 sending register messaages to the sip source address on the vgwbut when I debug ccsip on the gateway I don't see any activity at all. Here's my the sip config on the gateway:
voice service voip
allow-connections sip to sip
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server
voice register global
max-dn 30
max-pool 2
voice register pool 1
id network 172.18.20.0 mask 255.255.255.0
proxy 172.16.220.254
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 2
id network 172.17.120.0 mask 255.255.255.0
dtmf-relay rtp-nte
codec g711ulaw
sip-ua
registrar ipv4:172.16.220.254 expires 600
Please let me know if you see an error in the config or have a suggestion to resolve this.
Thank you
02-26-2013 06:19 AM
So I worked with TAC on this and we exported the traffic directly from the vgw interface to confirm the same from above. The phone SIP register messages arrive at the gateway and after a reboot of the vgw they were even accepted and the phone showed as registered on the vgw but the gateway itself never replies to the phone so it just sits there in 'registering' mode. I'll update here when we conclude what the issue is.
02-26-2013 11:18 AM
The issue ending up being a misconfiguration under call-manager-fallback. I mistakenly put in 'ip source-address x.x.x.x port 5060' which was conflicting with voice register global. I'm still not sure why the sniffer didn't show the actual SIP IP packets coming in, but the phones are working so I won't push my luck....
