SIP SRST
SS_MO7722
Dear All
Kindly i have an issue with enable srst it is not work , we try to enable SRST in router 2901 and router license is
License Type: EvalRightToUse
License State: Active, In Use
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 1 day
and our CUCM V10.5 , and  IP phones type 7841 and kindly find below running configuration:-
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0.2
bind media source-interface GigabitEthernet0/0.2
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice register global
mode srst
system message SRST Service Active
max-dn 35
max-pool 35
voice register pool 1
id network 10.200.200.0 mask 255.255.255.0
dtmf-relay rtp-nte sip-notify
voice-class codec 1
application
global
service alternate default
license accept end user agreement
hw-module pvdm 0/0
encapsulation dot1Q 2
ip address 10.200.200.1 255.255.255.0
mgcp
mgcp call-agent 10.5.5.200 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode cisco
mgcp bind control source-interface GigabitEthernet0/0.2
mgcp bind media source-interface GigabitEthernet0/0.2
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager config server 10.5.5.200
ccm-manager config
dial-peer voice 1 pots
destination-pattern 9T
port 0/0/0
sip-ua
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 2
ip source-address 10.2.2.1 port 2000
max-ephones 35
max-dn 35
system message primary SRST Mode
keepalive 20
time-zone 25
date-format dd-mm-yy
*** this is current configuration there is any missing configuration
zdesignstudio
Level 4
Level 4
In the SRST config under the device pool in CUCM does it have the information for the router?
Please rate useul posts and mark answers as correct if applicable.
Please rate useful posts and mark answers as correct if applicable.
yes we create SRST and mention Router voice gateway to this SRST and create new device pool and assign this SRST to this Device pool .
During SRST, from the router issue a "show voice registrar pool all" and see if the router is receiving the requests.
