SIP-to-SIP caller id with CUBE??
wtribble80
Can anyone explain the default behavior of CUBE in regards to caller ID in a SIP-to-SIP environment?
This is our setup:  CUCM 7.x <----sip---> CUBE <----sip-----> Paetec SIP service
The recommended configuration from Cisco for Paetec is to use  "no remote-party-id" in the sip-ua configuration.  However, I should still be able to get named caller id in the FROM header.  I see names being passed to us from Paetec, but CUBE strips the names in the TO and FROM headers of the INVITE message.
The only documentation i can find regarding SIP and clid are concerned with ISDN to SIP.  I need to understand the SIP to SIP clid behavior and how I can manipulate it.  This is the only Cisco documentation I have found so far:  http://www.ciscosystems.com/en/US/docs/ios/12_4t/12_4t4/FeatTP.html#wp1079374
We are using the latest version of code on the gateway - 12.4(24)T3
Here is an example of what I see on the packet trace.  IP's and numbers have been changed for privacy.
------------FROM PAETEC to CUBE-------------
From: "Name of Client "<sip:5555555555@172.16.1.1;user=phone>;tag=1691108409-1271338395236-
To: "Ourbusinessname"<sip:5558675309@10.10.2.13;4342608is=4342608is-u27gphf06l0ob>
-----------FROM CUBE to Call Manager-----------
To:  <sip:5558675309@10.10.1.21>
wtribble80
bump
