09-17-2009 05:21 AM - edited 03-15-2019 07:47 PM
I'm using a unified 500 to configure a sip trunk via the configuration assistant application.
I get no incoming calling or outgoing calling but when I do a 'debug ccsip message' I can see the incoming call hitting the router. I have attached this output in the attachment 'log-dial-in'.
Any pointers greatly appreciated
09-17-2009 06:31 AM
I'm sure it's now working outbound but not inbound.
09-17-2009 07:02 AM
Hi Craig,
I would make sure that the ACL in this configuration:
voice source-group CCA_SIP_SOURCE_GROUP
access-list 2
translation-profile incoming SIP_Incoming
It needs to be accurate, otherwise you will have this behavior. From the looks of it, you have 91.195.228.20 but the invite comes from 91.85.231.114
hth,
nick
09-17-2009 07:07 AM
Hi, I have checked and I'm sure it is correct. The 114 address is the system. When I call the number I get the info in the debug.
09-17-2009 07:49 AM
Hi Craig,
Access list 2 doesn't have that IP address.
-nick
