SIP trunk register
cm6043
I have make sip to a service provider in USA but I can't succeed in register. Please refer to the following debug ccsip message.
001331: Oct 8 10:40:58.319 HK: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:63.129.63.yyy:5060 SIP/2.0
Via: SIP/2.0/UDP 220.184.24.xxx:5060;branch=z9hG4bKA312CC
To: <sip:9*@63.129.63.yyy>
Date: Thu, 08 Oct 2009 02:40:58 GMT
Call-ID: E95749D4-B2E211DE-807AA4D2-2EF52498
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1254969658
CSeq: 19 REGISTER
Contact: <sip:9*@220.184.24.xxx:5060>
Expires: 3600
Content-Length: 0
001476: Oct 8 10:51:00.715 HK: //1327/000000000000/SIP/Error/act_sent_register_wait_100: act_sent_register_wa
it_100: Out of retries
001477: Oct 8 10:51:00.715 HK: //1327/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Clas
s 4xx Method Code 100 received for REGISTER
Leung Che Man
11 Replies 11
virverma
Level 4
Level 4
Could you explain this more,
how you going to make SIP trunk to SP,
What are the parameters involved in making a SIP trunk from customer directly to SP and how SP is allowing it?
Hi Virverma,
I have the username / password and SIP server IP. Please find my config of SIP trunk for your reference.
interface FastEthernet0/0
ip address 220.184.24.xxx 255.255.255.240
ip virtual-reassembly
speed 100
full-duplex
max-reserved-bandwidth 100
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 nse force ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
sip
voice class codec 729
codec preference 1 g711ulaw
codec preference 2 g729br8
codec preference 3 g711alaw
voice class codec 711
dial-peer voice 888888 voip
description **Outgoing Call to SIP Trunk**
huntstop
preference 2
service session
destination-pattern 7T
progress_ind setup enable 3
no modem passthrough
voice-class codec 729
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
gateway
timer receive-rtp 1200
sip-ua
hookflash-info
authentication username 2024491446 password 014156560F5F5F5E751818
no remote-party-id
set pstn-cause 47 sip-status 486
retry invite 2
retry response 3
retry bye 3
retry prack 6
retry options 0
timers expires 300000
mwi-server ipv4:63.129.63.yyy expires 3600 port 5060 transport udp unsolicited
registrar ipv4:63.129.63.yyy expires 3600
sip-server ipv4:63.129.63.yyy
Leung Che Man
Try to use something simple as below, then check show sip reg st
sip-ua
credentials username x password y realm IP
authentication username x password y
registrar ipv4:IP expires 3600
sip-server ipv4:IP
The SP likely wants the "From" header to contain the DID they gave you. You are currently sending them "9*" in the From header. Try changing the POTS dial peer to the SP DID to see if that will put the DID in the From header and trigger the SP to send a 401 or 407 response.
Hi Steven,
I have made some change in the config but the register is still failed. Could you let me know whether the username in dial peer 8 and sip ua should be same ? If not, what value I want to put. SP just provde me the 2024491446 and username/ password.
dial-peer voice 8 pots
destination-pattern 2024491446
port 0/0/0
authentication username 2024491446 password 124AAAAAAAAA72
sip-ua
credentials username 2024491446 password 15405B5EABC%%57C6763 realm 63.129.63.yyy
authentication username 2024491446 password 014$%#@CC0F5F5F5E751818
Line peer expires(sec) registered
2024491446 8 154 no
Leung Che Man
What does "debug ccsip messages" show now? Is the From header user portion 2024491446? Is the SP sending back any response?
The usual suspects are:
1) firewall/NAT - I assume all is good.
2) TCP vs. UDP - I think most/all SP support UDP.
3) Message config - This is the From header.
4) Bad SP info - Did the SP give you the right IP address? You could use X-lite to verify that the SP information is correct. The SP may have instructions on how to setup X-lite or some other free client.
I changed the sip server IP. I can make a incoming call from 1441 to 1446, it is successful. but outgoing call is failed.
013041: Oct 12 11:21:33.254 HK: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:xx.xx.xx.xx:5060 SIP/2.0
Via: SIP/2.0/UDP 220.yy.yy.yy:5060;branch=z9hG4bK4F8D17
To: <>2024491446@xx.xx.xx.xx>
Date: Mon, 12 Oct 2009 03:21:33 GMT
Call-ID: 371BCEA4-B60F11DE-81069715-5CDDDD4A
Max-Forwards: 70
Timestamp: 1255317693
CSeq: 17 REGISTER
Contact: <>2024491446@220.yy.yy.yy:5060>
Expires: 3600
Content-Length: 0
013042: Oct 12 11:21:33.506 HK: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not found
To: <>2024491446@xx.xx.xx.xx>;tag=1182030281-1255317693379
CSeq: 17 REGISTER
Content-Length: 0
Leung Che Man
I find that the xx.xx.xx.xx of from header is the service provider ip not our ip. How can I change this IP ?
Thanks a lot
Leung Che Man
Try adding to your voip dialpeer:
voice-class sip localhost dns:serviceprovider.com
Hi Steven,
The localhost added but the From header is still not changed. Is it the reason (From header not my source IP) I can't register to SIP ?
000149: Oct 13 09:36:22.554 HK: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP aa.aa.aa.aa:5060;branch=z9hG4bK1448A
000152: Oct 13 09:39:23.029 HK: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Leung Che Man
Yes, many of the SP want/expect the From header to be DID@serviceprovider.com. You would have to ask the SP for the definitive answer.
Ooops, the REGISTER message does not use that dial-peer, so you will have to make the setting global. Try:
voice service voip
sip
