SIP-UA ITSP GATEWAY PROBLEM!
caytos1989
Hello all, i have a 3945 configured as an H323 Gateway for my CUCM cluster....in this gateway, i have also configured the following ITSP:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 300 min 60
  no call service stop
voice class sip-profiles 1
request INVITE sip-header From modify "(<.*:)(.*@)" "\1caytoscarlosguardia@"
request ACK sip-header From modify "(<.*:)(.*@)" "\1caytoscarlosguardia@"
request INVITE sip-header Contact modify "(<.*:)(.*@)" "\1caytoscarlosguardia@"
request INVITE sip-header CSeq modify "101 INVITE" "2 INVITE"
request INVITE sdp-header Connection-Info add "IN IP4 200.87.213.138"
dial-peer voice 3 voip
destination-pattern 00T
session protocol sipv2
session target sip-server
no voice-class sip early-offer forced
voice-class sip profiles 1
dtmf-relay rtp-nte
codec g711alaw
no vad
sip-ua
credentials username caytoscarlosguardia password 7 *********************** realm sip.nonoh.net
authentication username caytoscarlosguardia password 7 ******************************* realm sip.nonoh.net
retry invite 2
retry register 10
retry options 1
timers connect 100
registrar dns:sip.nonoh.net expires 3600
sip-server dns:sip.nonoh.net
host-registrar
When i dial a number..all i get is a busy signal....doing a debug i found out that Im getting a Bad Request because there is no SDP DATA !!!!!
Dec 21 22:49:50.429: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0018005532447@sip.nonoh.net:5060 SIP/2.0
Via: SIP/2.0/UDP 200.87.213.138:5060;branch=z9hG4bK22BF11CF
Remote-Party-ID: <sip:4335@200.87.213.138>;party=calling;screen=yes;privacy=off
From: <sip:caytoscarlosguardia@sip.nonoh.net>;tag=2A74EBEC-2418
To: <sip:0018005532447@sip.nonoh.net>
Date: Tue, 21 Dec 2010 22:49:50 GMT
Call-ID: 73CFC231-C8B11E0-950BEDD1-F328D0C0@200.87.213.138
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2147533724-0237965777-0083914242-2886733854
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 2 INVITE
Max-Forwards: 70
Timestamp: 1292971790
Contact: <sip:caytoscarlosguardia@200.87.213.138:5060>
Expires: 180
Allow-Events: telephone-event
Content-Length: 0
Dec 21 22:49:50.693: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 400 Bad request
Contact: sip:0018005532447@194.120.0.198:5060
CSeq: 2 INVITE
Server: (Very nice Sip Registrar/Proxy Server)
Allow: ACK,BYE,CANCEL,INVITE,REGISTER,OPTIONS,INFO,MESSAGE
Content-Length: 0
Dec 21 22:49:50.697: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SCZ-R3945-01#ACK sip:0018005532447@sip.nonoh.net:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Ive spent 4 HOURS trying to troubleshoot this...and i figured this out.....if i add
request INVITE sip-header Content-Type add "Content-Type: application/sdp"
to my sip-profile.....i get this in my debug
Dec 21 22:52:02.481: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 200.87.213.138:5060;branch=z9hG4bK22C01E7F
From: <sip:caytoscarlosguardia@sip.nonoh.net>;tag=2A76EFC0-21BE
Date: Tue, 21 Dec 2010 22:52:02 GMT
Call-ID: C28375C0-C8B11E0-9510EDD1-F328D0C0@200.87.213.138
Min-SE:  1800
Cisco-Guid: 2157605099-2452558289-0100691714-2886733854
CSeq: 2 INVITE
Max-Forwards: 70
Timestamp: 1292971922
Expires: 180
Content-Length: 0
Dec 21 22:52:02.745: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
CSeq: 2 INVITE
WWW-Authenticate: Digest realm="sip.nonoh.net",nonce="1033179704",algorithm=MD5
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 200.87.213.138:5060;branch=z9hG4bK22C11590
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Authorization: Digest username="caytoscarlosguardia",realm="sip.nonoh.net",uri="sip:0018005532447@sip.nonoh.net:5060",response="29f0ff98da3a78e6f0ac88691e4ce1e8",nonce="1033179704",algorithm=MD5
Content-Length: 0
Dec 21 22:52:03.017: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
Dec 21 22:52:03.021: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 415 Unsupported media type
CSeq: 102 INVITE
Content-Length: 0
Dec 21 22:52:03.025: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
HOW DO I TURN SDP ON!!!!!???????????
THANK YOU SO MUCH!!!
21 Replies 21
There should be two RTP streams set up as per the following topology:
PSTN--[SIP]--CUBE--[SIP]--CUCM--[SCCP]--IP Phone
RTP Stream should be between -
PSTN SIP provider -----RTP----CUBE
and
CUBE----RTP----IP Phone
Based on the debugs RTP should be set up between the following IPs:
172.16.64.36 and 64.61.93.189
172.16.64.36 and 172.16.2.36
Since the IP phone can hear PSTN RTP from 64.61.93.189 to 172.16.64.36 terminates correctly and RTP from 172.16.64.36 is being sent to 172.16.2.36
Now make sure that you can ping 172.16.2.36 and 64.61.93.189 with a source address of 172.16.64.36
If above is failing then routing is not correct.
Guys please help me finish this project...its almost working....for some reason..when i call a United States number...i wont hear a thing theyre saying..but if i call another country..i can hear them..and they can hear me perfectly..but theres still no DTMF neither to the United States nor any country...heres a last debug if anyone is willing to give it a shot...
I include a show sip-ua call !
SCZ-R3945-01#
Dec 27 23:13:01.528: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:18005532447@200.87.213.138:5060 SIP/2.0
Via: SIP/2.0/TCP 172.16.32.3:5060;branch=z9hG4bKa8b16c16cbe
From: "Carlos Guardia" <4335>;tag=577437d4-e4d0-42b6-90a7-884616201781-35235504
To: <18005532447>
Date: Mon, 27 Dec 2010 23:13:01 GMT
Call-ID: d8574200-d1911d7d-212-32010ac@172.16.32.3
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.0
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Contact: <4335>
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <172.16.32.3:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 3629597184-3515948413-0000000204-0052433068
Session-Expires:  1800
P-Asserted-Identity: "Carlos Guardia" <4335>
Remote-Party-ID: "Carlos Guardia" <4335>;party=calling;screen=yes;privacy=off
Max-Forwards: 70
Content-Length: 210
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 172.16.32.3
s=SIP Call
c=IN IP4 172.16.32.3
t=0 0
m=audio 24924 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Dec 27 23:13:01.532: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <18005532447>
CSeq: 101 INVITE
Allow-Events: kpml, telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Dec 27 23:13:01.888: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:18005532447@jfk-primary.voicepulse.com:5060 SIP/2.0
Via: SIP/2.0/UDP 200.87.213.138:5060;branch=z9hG4bK286622ED
From: "Carlos Guardia" <>RgV51xhS53@jfk-primary.voicepulse.com>;tag=49704F7C-1182
To: <>18005532447@jfk-primary.voicepulse.com>
Call-ID: AF76B945-114511E0-A6D6EDD1-F328D0C0@200.87.213.138
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1293491581
Contact:
Call-Info: <200.87.213.138:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 197
v=0
o=CiscoSystemsSIP-GW-UserAgent 5922 4677 IN IP4 200.87.213.138
s=SIP Call
c=IN IP4 200.87.213.138
t=0 0
m=audio 21504 RTP/AVP 0
a=ptime:20
Dec 27 23:13:02.120: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SCZ-R3945-01#SIP/2.0 100 Giving a try
Via: SIP/2.0/UDP 200.87.213.138:5060;branch=z9hG4bK286622ED;rport=49336
CSeq: 101 INVITE
Server: OpenSER (1.3.2-notls (i386/linux))
Content-Length: 0
SCZ-R3945-01#
Dec 27 23:13:04.488: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 200.87.213.138:5060;rport=49336;branch=z9hG4bK286622ED
Record-Route: <64.61.93.190>
To: <>18005532447@jfk-primary.voicepulse.com>;tag=as79bcebfe
CSeq: 101 INVITE
User-Agent: VoicePulse PBX
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Contact: <>
Content-Length: 180
v=0
o=root 3368 3368 IN IP4 64.61.93.21
s=session
c=IN IP4 64.61.93.21
t=0 0
m=audio 15420 RTP/AVP 0
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Dec 27 23:13:04.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <18005532447>;tag=497059A8-1CFC
CSeq: 101 INVITE
Remote-Party-ID: <18005532447>;party=called;screen=yes;privacy=off
Contact: <18005532447>
Supported: sdp-anat
Content-Length: 196
v=0
o=CiscoSystemsSIP-GW-UserAgent 472 5399 IN IP4 200.87.213.138
s=SIP Call
t=0 0
m=audio 17784 RTP/AVP 0
a=ptime:20
Dec 27 23:13:04.496: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:18005532447@200.87.213.138:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.16.32.3:5060;branch=z9hG4bKa8c44aab940
CSeq: 102 SUBSCRIBE
Date: Mon, 27 Dec 2010 23:13:04 GMT
Event: kpml
Expires: 7200
Contact: <172.16.32.3:5060>
Accept: application/kpml-response+xml
Max-Forwards: 70
Content-Type: application/kpml-request+xml
Content-Length: 370
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0">
    [x*#ABCD]
Dec 27 23:13:04.500: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 SUBSCRIBE
Content-Length: 0
Expires: 7200
Sent:
NOTIFY sip:172.16.32.3:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 200.87.213.138:5060;branch=z9hG4bK286726A6
To: "Carlos Guardia" <4335>;tag=577437d4-e4d0-42b6-90a7-884616201781-35235504
CSeq: 101 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: active
Content-Length: 0
Received:
SCZ-R3945-01#SIP/2.0 200 OK
CSeq: 101 NOTIFY
Content-Length: 0
Dec 27 23:13:05.092: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Content-Length: 0
Dec 27 23:13:05.096: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:+18005532447@200.87.213.138:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.16.32.3:5060;branch=z9hG4bKa8d15f3a007
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
SUBSCRIBE sip:172.16.32.3:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 200.87.213.138:5060;branch=z9hG4bK28691581
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
Date: Mon, 27 Dec 2010 23:13:05 GMT
Event: kpml
Expires: 7200
Content-Length: 327
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0">[x*#ABCD]
Dec 27 23:13:05.100: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 SUBSCRIBE
Content-Length: 0
Expires: 7200
Received:
NOTIFY sip:18005532447@200.87.213.138:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.16.32.3:5060;branch=z9hG4bKa8e4de0587f
CSeq: 103 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: active;expires=7200
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 103 NOTIFY
Content-Length: 0
Dec 27 23:13:05.288: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Contact: <>
Content-Length: 180
v=0
o=root 3368 3369 IN IP4 64.61.93.21
s=session
t=0 0
a=ptime:20
a=sendrecv
Sent:
SCZ-R3945-01#ACK sip:+18005532447@64.61.93.21:5060 SIP/2.0
Via: SIP/2.0/UDP 200.87.213.138:5060;branch=z9hG4bK28682014
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
SCZ-R3945-01#
Dec 27 23:13:11.492: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 172.16.32.3:5060;branch=z9hG4bKa8f4e57946e
CSeq: 104 NOTIFY
Max-Forwards: 70
Date: Mon, 27 Dec 2010 23:13:11 GMT
Event: kpml
Subscription-State: active;expires=7194
Content-Type: application/kpml-response+xml
Content-Length: 336
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-response kpml-response.xsd" code="200" digits="0" forced_flush="false" suppressed="false" tag="dtmf" text="Success" version="1.0"/>
Sent:
CSeq: 104 NOTIFY
Content-Length: 0
SCZ-R3945-01#
Dec 27 23:13:13.280: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 172.16.32.3:5060;branch=z9hG4bKa903270f2c0
CSeq: 105 NOTIFY
Max-Forwards: 70
Date: Mon, 27 Dec 2010 23:13:13 GMT
Event: kpml
Subscription-State: active;expires=7192
Content-Length: 336
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-response kpml-response.xsd" code="200" digits="1" forced_flush="false" suppressed="false" tag="dtmf" text="Success" version="1.0"/>
Sent:
CSeq: 105 NOTIFY
Content-Length: 0
SCZ-R3945-01#show sip-ua calls
SIP UAC CALL INFO
Call 1
SIP Call ID                : AF76B945-114511E0-A6D6EDD1-F328D0C0@200.87.213.138
   State of the call       : STATE_ACTIVE (7)
   Substate of the call    : SUBSTATE_NONE (0)
   Calling Number          : 4335
   Called Number           : 18005532447
   Bit Flags               : 0xC04018 0x100 0x0
   CC Call ID              : 15483
   Source IP Address (Sig ): 200.87.213.138
   Destn SIP Req Addr:Port : [64.61.93.190]:5060
   Destn SIP Resp Addr:Port: [64.61.93.190]:5060
   Destination Name        : jfk-primary.voicepulse.com
   Number of Media Streams : 1
   Number of Active Streams: 1
   RTP Fork Object         : 0x0
   Media Mode              : flow-through
   Media Stream 1
     State of the stream      : STREAM_ACTIVE
     Stream Call ID           : 15483
     Stream Type              : voice-only (0)
     Stream Media Addr Type   : 1
     Negotiated Codec         : g711ulaw (160 bytes)
     Codec Payload Type       : 0
     Negotiated Dtmf-relay    : inband-voice
     Dtmf-relay Payload Type  : 0
     QoS ID                   : -1
     Local QoS Strength       : BestEffort
     Negotiated QoS Strength  : BestEffort
     Negotiated QoS Direction : None
     Local QoS Status         : None
     Media Source IP Addr:Port: [200.87.213.138]:21504
     Media Dest IP Addr:Port  : [64.61.93.21]:15420
Options-Ping    ENABLED:NO    ACTIVE:NO
   Number of SIP User Agent Client(UAC) calls: 1
SIP UAS CALL INFO
Call 1
SIP Call ID                : d8574200-d1911d7d-212-32010ac@172.16.32.3
   Bit Flags               : 0xC0401E 0x300 0x4
   CC Call ID              : 15482
   Destn SIP Req Addr:Port : [172.16.32.3]:5060
   Destn SIP Resp Addr:Port: [172.16.32.3]:48820
   Destination Name        : 172.16.32.3
   Media Stream 1
     Stream Call ID           : 15482
     Negotiated Dtmf-relay    : sip-kpml
     QoS ID                   : -1
     Media Source IP Addr:Port: [200.87.213.138]:17784
     Media Dest IP Addr:Port  : [172.16.32.3]:24924
   Number of SIP User Agent Server(UAS) calls: 1
SCZ-R3945-01#
SCZ-R3945-01#
IS THERE A WAY TO MAKE IT FLOW-AROUND?? OR IT DOESNT MATTER??
Hi Carlos,
to make sure from what does SP support for dtmf, please get logs for incoming call.
also try to press digits during the call, you need to know also the ip phone dtmf capability that you use
what is the phone model and protocol?
for the audio problem, disable sip media binding and use the command address-hiding under voice service sip
this will enable embedded NAT.
B.R./Haitham
If this helps, please rate
ITS FINALLY WORKING GUYS!!!!
DTMF works perfectly! and all the calls also work with excellent audio quality!!! THANKS TO ALL OF YOU GUYS..!! here's my final config if anyone has the same issues: ONE MORE THING THOUGHT....im having problems with INCOMING CALLS from my SP....it matches a dial-peer 3 as outgoing and tries to establish a sip session with my SP and then my sp sends the invite to me and its a BIG LOOP!!!
All i want is to send ALL incoming calls from my SP to an extension number: 4208
Please help me in this last STEP.
voice service voip
address-hiding
dtmf-interworking rtp-nte
no supplementary-service sip moved-temporarily
h323
  emptycapability
  h225 id-passthru
sip
  bind control source-interface GigabitEthernet0/1
  early-offer forced
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class codec 2
codec preference 1 ilbc
codec preference 2 g711ulaw
request INVITE sip-header From modify "(<.*:)(.*@)" "\1RgV51xhS53@"
request ACK sip-header From modify "(<.*:)(.*@)" "\1RgV51xhS53@"
request INVITE sip-header Contact modify "(<.*:)(.*@)" "\1RgV51xhS53@"
dial-peer voice 4 voip
incoming called-number .T
voice-class codec 2
dtmf-relay sip-kpml sip-notify rtp-nte cisco-rtp
destination-pattern .T
voice-class codec 2
dtmf-relay sip-notify sip-kpml rtp-nte cisco-rtp
dial-peer voice 1 voip
destination-pattern [3-5]...
session target ipv4:172.16.32.3
sip-ua
credentials username RgV51xhS53 password XXXXXXXXXX realm jfk-primary.voicepulse.com
authentication username RgV51xhS53 password XXXXXXXXXXXXXX realm jfk-primary.voicepulse.com
retry invite 2
retry register 10
retry options 1
timers connect 100
registrar dns:jfk-primary.voicepulse.com expires 3600
sip-server dns:jfk-primary.voicepulse.com
host-registrar
Hi Carlos,
Glad to hear it worked
add this for translate any called number to 4208
conf t
voice translation-rule 1
rule 1 /.*/ /4208/
voice translation-profile test
translate called 1
then under incoming dial-peers from SP add "translation-profile incoming test"
B.R/Haitham
Please Rate ...
`Thanks...but I dont think I have an incoming dial-peer for my SP...I only created one for the trunk between my CUCM and my CUBE...how can the router tell the diference...because if i apply the translation-profile to THAT dial-peer voice 4....then it will translate ALL calls??
Im still having problems with my Inbound calls...its being stucked in a Loop!!
anyone? please?
