SIP URI format displayed in Jabber or Phone display
marcel.pludra
Hi all,
if i make a SIP URI call to a CMS space (xxxx.space@domain.de) from Jabber or IP Phone, the connected URI in display is "xxxx.space@192.168.XXX.XXX" . The displayed IP after "@" is the CUCM IP.
But I want, that the domain is displayed instead of the IP of CUCM. This format: "xxxx.space@domain.de"
How can i adjust this ?
Does i have to change something in the SIP Profile for SIP trunk?
Thanks for helping ;)
-##Use the following
Create a SIP profile and put a check mark beside “Use fully qualified name”
That's the solution. I forgot to check it in the SIP Profile for the enddevice (Jabber). I only checked it in the profile to the trunk.
Thanks for your help.
