08-04-2015 01:23 AM - edited 03-17-2019 03:51 AM
Hey ,
I have a firmware upgrade problem, our current firmware is SIP8941_8945.9-3-2-12, and will upgrade it to 9.3.4.17 version, some of phones in cluster have the belowed failed, any suggestions ?
CM Version 9.1.2
X.X.X.24 = our TFTP Server IP
Console Logs
* Rate limit enabled *
18:37:09, 08/03/2015 : CTLSEP20BBC0DE1167.tlv updating
18:38:09, 08/03/2015 : CTLSEP20BBC0DE1167.tlv not found in X.X.X.24
18:38:09, 08/03/2015 : ITLSEP20BBC0DE1167.tlv updating
18:39:07, 08/03/2015 : ITLSEP20BBC0DE1167.tlv (HTTP)
18:39:07, 08/03/2015 : ITLSEP20BBC0DE1167.tlv updated successfully
18:39:07, 08/03/2015 : ITL installed
18:40:13, 08/03/2015 : SEP20BBC0DE1167.cnf.xml.sgn (HTTP)
Authenticating configuration file SEP20BBC0DE1167.cnf.xml.sgn successfully
TID: 0x3b task name: PROVISION tag name: phoneOffTime value : 24:00 is error format.
Authenticating SIP8941_8945.9-3-4-17.loads file successfully.
BOOT8941_8945.0-0-1-0.bin.sgn
SIP8941_8945.9-3-4-17.bin1.sgn
SIP8941_8945.9-3-4-17.bin2.sgn
SIP8941_8945.9-3-4-17.bin3.sgn
SIP8941_8945.9-3-4-17.bin4.sgn
SIP8941_8945.9-3-4-17.bin5.sgn
SIP8941_8945.9-3-4-17.bin6.sgn
SIP8941_8945.9-3-4-17.bin7.sgn
SIP8941_8945.9-3-4-17.bin8.sgn
SIP8941_8945.9-3-4-17.bin9.sgn
SIP8941_8945.9-3-4-17.bin10.sgn
cfgmgr_loads_task(): image_flag: 10
[0x30400000] 0xa1
[0x30400008] 0xa1
set_vlan_id vlan 1.2
[0x3041a030] 0x1d
[0x30400000] 0xa0
[0x30400008] 0xa0
18:41:07, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin1.sgn from X.X.X.24
rm: cannot remove '/tmp/ota_LYNETTE.bin': No such file or directory
Authenticating SIP8941_8945.9-3-4-17.bin1.sgn file successfully.
flash_eraseall started for /dev/mtd8
ota_Erase_All /dev/mtd8 begin
ota_Erase_All /dev/mtd8 end rc1=0
flash_eraseall done for /dev/mtd8
flash_eraseall started for /dev/mtd10
ota_Erase_All /dev/mtd10 begin
ota_Erase_All /dev/mtd10 end rc1=0
flash_eraseall done for /dev/mtd10
18:43:53, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin2.sgn from X.X.X.24
Transfer Timed Out.
File transfer error.
tftp_download_file, 169
tftp_download_file, 186
18:46:57, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin2.sgn fail (read fail)
18:46:57, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin3.sgn from X.X.X.24
Transfer Timed Out.
18:47:09, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin3.sgn fail (read fail)
18:47:10, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin4.sgn from X.X.X.24
Transfer Timed Out.
18:47:22, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin4.sgn fail (read fail)
18:47:22, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin5.sgn from X.X.X.24
Transfer Timed Out.
18:47:34, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin5.sgn fail (read fail)
18:47:34, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin6.sgn from X.X.X.24
Transfer Timed Out.
18:47:46, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin6.sgn fail (read fail)
18:47:46, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin7.sgn from X.X.X.24
Transfer Timed Out.
18:47:58, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin7.sgn fail (read fail)
18:47:58, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin8.sgn from X.X.X.24
Authenticating SIP8941_8945.9-3-4-17.bin8.sgn file successfully.
18:50:17, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin9.sgn from X.X.X.24
Authenticating SIP8941_8945.9-3-4-17.bin9.sgn file successfully.
18:52:27, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin10.sgn from X.X.X.24
keypad_input 368: Cancel run in
Authenticating SIP8941_8945.9-3-4-17.bin10.sgn file successfully.
Software Upgrade Failed. fcrc 0x5b0b582b != 0xfa1b055c
18:54:41, 08/03/2015 : upgrade SIP8941_8945.9-3-4-17.bin10.sgn fail (read fail)
*** cfgmgr_loads_task 1826 callback return ***
18:54:41, 08/03/2015 : Upgrade Failed
No need to download locale resources. (Turkish_Turkey, 9.1.1.1000-1, X.X.X.24/Turkish
Turkey, 9.1.1.1000-1, X.X.X.24)
18:56:36, 08/03/2015 : SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn (HTTP)
Authenticating configuration file SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn successf
lly
del sess node
18:56:37, 08/03/2015 : VPN Error: VPN is not Configured.
26:02:23:46.038 - Checking Protocol: Device=SIP. Config=SIP (OK)
26:02:23:46.039 - Checking SwPort: 100-full (OK)
26:02:23:46.039 - Checking Network: IPV4 - 42.143.245.27 (OK)
26:02:23:46.040 - Checking Security: NonSecure Mode (LSC: Not Installed, MIC: Installed)
OK)
26:02:23:46.040 - Checking Account: Line (OK)
26:02:23:46.042 - Checking CUCM1: IPv4 - X.X.X.22 (OK)
26:02:23:46.042 - Checking CUCM2: IPv4 - X.X.X.21 (OK)
26:02:23:46.042 - Checking TFTP0: IPv4 - X.X.X.24 (OK)
[MMI]Not update call ui on unregister
into subhandler_applications:provision_ready
26:02:23:46.543 - REG (OK)
path = /nvdata is exist
FFS Commit to /nvdata/CFG2.
Aug 3 16:54:40 kernel: backlight_store_brightness
Status Message
[18:36:37, 08/03/2015] Reset request by CUCM
[18:37:06, 08/03/2015] SEP20bbc0de1167 Get ip from DHCP server : X.X.245.27
[18:37:09, 08/03/2015] CTLSEP20BBC0DE1167.tlv updating
[18:38:09, 08/03/2015] CTLSEP20BBC0DE1167.tlv not found in X.X.X.24
[18:38:09, 08/03/2015] ITLSEP20BBC0DE1167.tlv updating
[18:39:07, 08/03/2015] ITLSEP20BBC0DE1167.tlv (HTTP)
[18:39:07, 08/03/2015] ITLSEP20BBC0DE1167.tlv updated successfully
[18:39:07, 08/03/2015] ITL installed
[18:40:13, 08/03/2015] SEP20BBC0DE1167.cnf.xml.sgn (HTTP)
[18:41:07, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin1.sgn from X.X.X.24
[18:43:53, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin2.sgn from X.X.X.24
[18:46:57, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin2.sgn fail (read fail)
[18:46:57, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin3.sgn from X.X.X.24
[18:47:09, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin3.sgn fail (read fail)
[18:47:10, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin4.sgn from X.X.X.24
[18:47:22, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin4.sgn fail (read fail)
[18:47:22, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin5.sgn from X.X.X.24
[18:47:34, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin5.sgn fail (read fail)
[18:47:34, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin6.sgn from X.X.X.24
[18:47:46, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin6.sgn fail (read fail)
[18:47:46, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin7.sgn from X.X.X.24
[18:47:58, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin7.sgn fail (read fail)
[18:47:58, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin8.sgn from X.X.X.24
[18:50:17, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin9.sgn from X.X.X.24
[18:52:27, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin10.sgn from X.X.X.24
[18:54:41, 08/03/2015] upgrade SIP8941_8945.9-3-4-17.bin10.sgn fail (read fail)
[18:54:41, 08/03/2015] Upgrade Failed
[18:56:36, 08/03/2015] SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgn (HTTP)
[18:56:37, 08/03/2015] VPN Error: VPN is not Configured.
08-05-2015 12:04 AM
Nobody has such experience ?any suggestion would be appreciated
Thanks in advance
