Softkey Error
juankcs85
Hi everyone
When i try to make a conference the ip phone in some cases is unable to complete, display a error un the screen, the same problem appears when i try transfer a call.
The problem occurs in the central site and remote sites
The cpu and memory load in call manager is normal
i don´t have idea what happen.
Jaime Valencia
You need to provide more details like CUCM version, call scenarios, etc
With that little info i believe this is PSTN calls with H323 and you're not allocating an MTP for the calls.
Check the MTP required option under GWs
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
