11-23-2015 07:48 AM - edited 03-18-2019 11:42 AM
My customer is expriencing a strange problem whereby some device configuration changes applied and saved on CUCM fail to apply to the device
So far the two settings are Video Capabilities and Display Idle Timeout
I have checked the likely Enterprise Parameters and Enterprise Phone Parameters and relevant settings appear to be enabled, any suggestions please?
CUCM version
10.5.2.12901-1
Device Firmware -Also tried an earlier version but the same result
SCCP69xx.9-4-1-3SR2
sip78xx.10-3-1-12
11-23-2015 08:21 AM
Hi Azeez,
Any other changes made apart from the above applies properly on the same phone? If not, its worth checking whether the ITL file is updated properly on these phones from the settings --> Status messages.
Rajan
11-23-2015 09:41 AM
Cheers Rajan. As far as i'm aware yes and i'll have them check status messages as adviced.
many thanks
11-23-2015 10:10 AM
great. if you see something like "ITL update failed" in the status message, try deleting the itl file by pressing the Applications button and choosing Admin Settings > Reset Settings > Security.
https://www.variphy.com/support/knowledge-base/delete-itl-file-reset-security-settings-on-cisco-7800-ip-phone
Rajan
