SPA508 auto provisioning
Oxygen2754
Hey
I have a list of cisco spa508g phone that i need to configure auto provisioning.
I have the mac addresses of each phone but  tftp is not an option so the config files will need to be transferred through HTTP.
I have not been able to retrieve the .xml file from the phones unfortunately because I am not on site but they have been configure with their extensions to out PBX.
I am currently trying to open a sample txt through the SPC tool but do not understand the syntax.
Can I please get instructions on how to do so and if there is a guide to use the SPCtool.
SPCtool version: spa50x-30x-sip-7-5-1a-spc-win32-i386
Jaime Valencia
You probably want to try the SMB forum for your question
java
if this helps, please rate
