SPA525G2 and Cisco 2851 Compatibility
intra
Is SPA525G2 and Cisco 2851 CME compatible ?
If yes, how is it possible, what are the config changes ?
paolo bevilacqua
On ISR routers, you can use the SPA phones with SIP firmware, as basic SIP phones with limited features.
You could also try configuring a custom ephone-type, with no guaranteed results.
ronpatel
Level 8
Level 8
Unfortunately no. These phones are supported with Cisco Unified Communications 500 Series for Small Business.
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
paolo bevilacqua
