Speakerphone Quality issue
Hello
I have phones 7970 that when I talk by Speakerphone the audio quality is low but the headset the quality is perfect.
This problem appear when I upgrade CM 4.1 to CM 7.1 the firmware version of phones is 8-4-1.
Any Idea of This Issue?????
Regards.
David Hailey
There are a few voice quality bugs on in firmware.  You can do a search for various tags in the forums and you'll come across several.  I recommend upgrading to something post 8-5-3 (I believe a number of fixes were noted in that revision) and then just run it individually on a few phones to see if that clears up your issue.
If not, we can help you go from there.  It could be a bug, it could also be a volume issue...sounds funny but true.
Hailey
Please rate helpful posts!
