Specific DN different after hours plan.
Jacob Berger
Level 2
Level 2
CUCM 8
is it possible to have a number ring on specific device by day. but after working hours number will go to hunt pilot?
thanks
Harmit Singh
Hi Jacob,
What you're looking for is time of day routing. Here is a nice doc which shows how to configure TOD with the help of an example:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080a7bc96.shtml
HTH.
Harmit.
5 Replies 5
Harmit Singh
Hi Jacob,
HTH.
Harmit.
does this work wtih internal calls or only external?
Hi Jacob,
It works irrespective of whether the calling party is internal or external. It all depends on who has access to call the Translation Patterns you configure for business hours and non business hours.
Harmit.
Thanks Harmit
will read the info.
My pleasure Jacob, see you around.
Harmit.
