have problems accessing the CUCM Express 9.1 by web. What can be the problem ??Thank alot !
According to the this document: http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#configs you can assign inbound and outbound translation-profiles to trunk groups, but it doesn't seem to work as adver...
Hello,can anyone point me to a hardware compatibility Matrix for CUC that lists all the versions? I want to make sure we upgrade to the highest possible revision support on the servers we have.Thanks. Replies rated.
Hello,We are facing a weird issue where our CUCM Publisher cannot boot up. I have already tried to repair the system through the Recovery Disk with no success.Find below the system messages:"Booting command-list root (hd0,0) Filesystem type is ext2f...
Hello,Just handed a CUC 1.x install (Don't laugh) and I need to change the VM password for a user. I am on the Edit User Basics Settings Page for the user but don't see a field for the VM password. There is a banner on the user's page saying that "...
HiI have recently purchased a srp527w and I am thinking to buy a Cisco wireless ip phone 7921g. Does it works with the srp527? Do I need another device between my srp527 and the ip phone? or it just works by configuring the voice vlan. If so, what...
Hello,Currently, my communicaitons manager is set up for 4 digit internal dialing. However, I want to create a new phone group on the same server that uses 3 digit internal dialing. I do not want the 4 digit dialing group to be able to dial the 3 dig...
Hi GuysI used the attached csv file for insert phones in cucm version 9.I recieve errors so it seems that in cucm version 9 the format is different than previous versions , because in cucm version 7-8 this format was correctCould you give some lights...
I'm trying to find a fax machine that is dialing a phone number by mistake. Apparently the fax machine is masked with our main number. I tried issuing a show log | begin Feb 5 06 on the gateway, however it's not returning any results. The same com...
I'm trying to configure an IAD2431 to register to CUCM 6.1 using MGCP. I have entered all of the MGCP commands and enabled 'mgcpapp' on the voice ports. I configured the gateway in CUCM as well, but it's not registering. I confirmed that the hostn...
On my CUCM system, I've set the enterprise parameters for "URL Directories" to point to my own server (http://x.x.x.x/cucmservices/dirlist ) This works fine on 79xx, 89xx, & 99xx phones.But for some reason, 69xx phones don't want to play ball. Instea...
Hello,Im having a bit of a hard time getting a new Valcom system setup.Currently my Vlacom V-2006a is plugged into my 0/1/1 FXO port. The Valcom and FXO are set to loop start.I have a dial peer that points the extension to be dialed (*79) to the port...
I'm wondering if anyone has found a fix for this yet...we've got over 1,000 9971s deployed in the US alone, with Europe going the remainder of this year. We've consistently had audio quality issues with these phones though...I believe it's mainly sp...
When buying a C220 for a UC install (4 VMs) do I need to purchase one or two of R-VMW-UC-FND5-K9 to cover the the two CPUs? thanks.
Hi GuysI am having some issues with MWI on unity 8. (CUCM Version 8.0) They dont come on or off .. however the email notification works fine.. in the windows event viewer i get a CiscoUnity_Notifier : Failed to set message waiting lamp for user...
Subject | Author | Posted |
06-09-2025 09:11 AM | ||
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM |
User | Count |
5 | |
2 | |
2 | |
1 | |
1 |
