SQL Command (Count)
jeremy.worden
Looking for some help with running an SQL command to count the number of trunks. This will return the count of most of the trunks:
run sql select count(tm.name) as Total from device as d inner join typemodel as tm on d.tkmodel = tm.enum where tm.name like '%Trunk%'
However I have a situation where I have multiple trunks with the same name but different Route Groups. This does not count the duplicates.
Basically looking for the cli equivalent of Device>Trunks
Thanks!
Aaron Harrison
Hey
Count:
run sql select count(*)  from routegroupdevicemap join device d on fkdevice = d.pkid join routegroup rg on fkroutegroup = rg.pkid
Check:
run sql select rg.name,d.name from routegroupdevicemap join device d on fkdevice = d.pkid join routegroup rg on fkroutegroup = rg.pkid
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Hey
Count:
Check:
Aaron
Aaron,
thanks for looking at this for me! so this is getting closer. now i seem to be missing trunks that dont have a route group assign (NULL). I have the same scenerio when trying to count CTI route points.
Thanks!
Jeremy
