SQL query syntax for date range
j.mccartney
Level 6
Level 6
Hello, I'm trying to write a query against CUCM6.1.2 that will give me all calls made to an extension for an inclusive range of dates. I want to say give me all calls made to extension "Z" for an example between September 9th and October 1st.
Here is what I was thinking would do it but it didn't and I've tried a bunch of things with no success:
run sql select callingpartynumber, originalcalledpartynumber, finalcalledpartynumber, duration, datetimestamporigination, datetimestampdisconnect from car:tbl_billing_data where datetimestamporigination > '2009-09-10' and finalcalledpartynumber IN ('3321')
Thanks in advance.
John
Dennis Fogler
John,
You can certainly use the syntax
SELECT * FROM db_table
WHERE date >= "1-SEP-2009"
AND date <= "5-SEP-2009" as an example.
I usually use the BETWEEN command
WHERE date BETWEEN "1-SEP-2009"
AND "5-SEP-2009"
Thanks for the response, I tried what you listed and it didn't work. I tried modifying the syntax based on known working query's but still not having any luck. I'll keep on trying. Thanks again for helping.
