SRST config problems
Jakub Stroinski
Level 4
Level 4
I'm trying to configure SRST on our gateway when CUCM goes down.
Our auto attendant is on DN 2000 in CUCM (goes to UCCX)
Our sample phones are 2001, 2339, 2340, 2810, 2820
2001 is a SIP 7821 while the others are SCCP phones
When the WAN is up, all phones ring instead of being answered by the auto attendant and are registered with CUCM.
When the WAN goes down, all phones ring as expected and are registered in SRST with the gateway.
In addition, when a call is answered on the SIP phone through SRST, no audio is heard. When a call is answered on the SCCP phone, there is audio.
I have tried using the alias command in call-manager-fallback; I set alias 1 2000 to 1999 and changed my hunt pilot to 1999 but that didn't work at all. If I set alias 1 2000 to 2339, my phone rings but not in the manner that I wish
I've pasted my config below. Any advice would be incredibly helpful
ROUTER#show run
Building configuration...
Current configuration : 5602 bytes
! Last configuration change at 08:54:37 EDT Thu Sep 10 2015 by USERNAME
! NVRAM config last updated at 08:54:38 EDT Thu Sep 10 2015 by USERNAME
version 15.1
hostname ROUTER
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.151-4.M10.bin
boot-end-marker
logging buffered 4096
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.16.16.1 172.16.16.20
ip dhcp pool voice
 import all
 network 172.16.16.0 255.255.255.0
 default-router 172.16.16.1
 option 150 ip 172.16.16.4
 dns-server 10.10.0.5
 lease 0 2
ip domain name lab.DOMAIN.com
ip name-server 172.16.16.1
ip name-server 10.10.0.5
no ipv6 cef
voice service voip
 ip address trusted list
  ipv4 XX.XX.XX.XX
  ipv4 172.10.10.0 255.255.255.0
  ipv4 172.16.16.0 255.255.255.0
 ip address trusted call-block cause not-in-cug
 gcid
 clid substitute name
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 sip
  e911
  registrar server expires max 600 min 60
  transport switch udp tcp
  asserted-id ppi
  midcall-signaling passthru
  no call service stop
voice class sip-profiles 1
 request INVITE sip-header From modify "From: (.*<)(.*>)" "From: \"Cisco Lab\" <\2"
voice register global
 timeouts interdigit 5
 max-dn 20
 max-pool 10
voice register pool  1
 id network 172.16.16.0 mask 255.255.255.0
 dtmf-relay rtp-nte cisco-rtp
 codec g711ulaw
voice hunt-group 20 parallel
 list 2001,2339,2340
 timeout 20
 pilot 2000
voice translation-rule 1
 rule 1 /.*/ /2000/
voice translation-rule 2
 rule 1 /.*/ /5555555555/
voice translation-rule 3
 rule 1 /^9\(.*\)/ /\1/
voice translation-profile INCOMING
 translate called 1
voice translation-profile OUTGOING
 translate calling 2
 translate called 3
voice-card 0
crypto pki trustpoint TP-self-signed-910207751
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-910207751
 revocation-check none
 rsakeypair TP-self-signed-910207751
license udi pid CISCO2811 sn FTX1126A20Z
archive
 log config
  hidekeys
username USERNAME privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXXX
redundancy
interface Loopback0
 no ip address
interface FastEthernet0/0
 description DHCPVoIP
 ip address 172.16.16.2 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.16.1
access-list 23 permit 172.16.16.0 0.0.0.255
access-list 23 permit 172.10.10.0 0.0.0.255
access-list 23 permit 10.10.0.0 0.0.0.255
tftp-server flash:apps75.9-4-2ES9.sbn
tftp-server flash:cnu75.9-4-2ES9.sbn
tftp-server flash:cvm75sccp.9-4-2ES9.sbn
tftp-server flash:dsp75.9-4-2ES9.sbn
tftp-server flash:jar75sccp.9-4-2ES9.sbn
tftp-server flash:SCCP75.9-4-2SR1-1S.loads
tftp-server flash:term75.default.loads
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x216x16/DOMAIN.png
tftp-server flash:Desktops/320x216x16/TN-DOMAIN.png
tftp-server flash:Desktops/320x196x4/List.xml
tftp-server flash:Desktops/320x196x4/DOMAINBW.png
tftp-server flash:Desktops/320x196x4/TN-DOMAINBW.png
control-plane
mgcp profile default
dial-peer voice 1 voip
 translation-profile incoming INCOMING
 session protocol sipv2
 incoming called-number 189199
 dtmf-relay cisco-rtp rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2 voip
 translation-profile outgoing OUTGOING
 destination-pattern 9[2-9]..[2-9]......
 session target ipv4:XX.XX.XX.XX
 no voice-class sip early-offer forced
 voice-class sip profiles 1
 dtmf-relay rtp-nte cisco-rtp sip-kpml sip-notify
 codec g711ulaw
 no vad
dial-peer voice 3 voip
 destination-pattern 2...
 session target ipv4:172.16.16.4
 codec g711ulaw
dial-peer voice 13 voip
 preference 1
 session target ipv4:172.16.16.2
 codec g711ulaw
dial-peer voice 14 voip
 preference 1
 codec g711ulaw
sip-ua
 credentials username 189199 password 7 XXXXXXXXXXXXXXXXXXXXXXXX realm SIPPROVIDER.com
 authentication username 189199 password 7 XXXXXXXXXXXXXXXXXXXXXXXX realm SIPPROVIDER.com
 registrar 1 dns:SIPPROVIDER.com expires 300
 secondary-dialtone 9
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 172.16.16.2 port 2000
 max-ephones 10
 max-dn 20
 keepalive 20
 time-zone 12
 time-format 24
 date-format dd-mm-yy
banner exec ^C
Authorized access only. This system is the property of DOMAIN. Disconnect IMMEDIATELY if you are not an authorized user!
^C
banner login ^C
^C
line con 0
 login local
line aux 0
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 192.67.222.4
end
ROUTER#
Jaime Valencia
If you want enhanced routing capabilities, you probably want to look into CME-as-SRST instead of plain SRST.
java
if this helps, please rate
Im looking at this
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmesrst.html
Everything is for SCCP phones it seems. Is there an equivalent for SIP?
I am not sure if I understand your requirement. If your question whether SIP supports SRST, the answer is yes.
Also, SIP SRST support hunt groups but as Jamie mentioned, you need CME-SRST instead of traditional SRST
Bringing this back from the dead
Under normal circumstances, when a call comes in on our gateway it is sent to 2000 which is a CTI port for UCCX
When we're in SRST mode, I would like all calls to go to extension 2339 on a SIP phone
If I modify my translation profile in my GW to point to 2339, it works. How would I go about having it automatically change to 2339 from 2000 when we fall to SRST mode?
