SRST Configuration for SIP Phones
Jagsuvce G
We have configured SRST for SCCP IP Phones and its working fine. But for SIP IP Phones 7821, am not sure what configs to be done on Gateways.
My configs on gateway are as follow...
application
global
service alternate Default
dial-peer voice 11 voip
destination-pattern 2....
session target ipv4:192.168.1.6
session transport tcp
dial-peer voice 12 pots
translation-profile incoming Incoming_Pstn
destination-pattern 0T
direct-inward-dial
port 0/0/1:15
forward-digits all
call-manager-fallback
max-conferences 12 gain -6
transfer-system full-consult
ip source-address 192.168.1.6 port 2000
max-ephones 720
max-dn 900
Pls suggest what all configs needs to be added for SIP Phones to work in SRST Model.
For Call Routing, you need not to do anything different opposed to what you should be doing currently anyways i.e, the required dial-peers should be there on the gateway already to route the calls out to PSTN.
There is nothing specific for SIP vs SCCP Phones, it all depends on the dial-plan and not the type of phone.
Deepak
Deepak
8 Replies 8
Rajan
You can refer the below documents for SIP SRST configuration:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/admin/sccp_sip_srst/configuration/guide/SCCP_and_SIP_SRST_Admin_Guide.pdf
Or modify the configuration shared in this thread according to your needs:
https://supportforums.cisco.com/discussion/11166176/sip-configuration-srst-ver-151-3t
Rajan
Deepak Rawat
Look at this great document by Kevin which covers everything that you require for SIP Phones to work in SRST along with the t/s steps involved:
https://supportforums.cisco.com/document/12746456/how-implement-cisco-unified-sip-srst
Deepak
Hi Deepak,
I am confused on this part...
sip-ua
registrar ipv4:192.168.0.2 expires 3600 >>> 192.168.0.2 is CUCM IP address
It should be SRST Router/Gateway IP Address right ??
The syntax is correct since CUCM is B2B UA, it can do the job. More details below:
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_r1_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1548510
Deepak
Hi Deepak,
Am confused,  can u pls explain a bit on this part ??  We are using all gateways - MGCP, so does this command really required ??
sip-ua
Pls suggest.
This command is specific for SIP gateways, in case you have MGCP you do not need it then.
BTW, this thing was mentioned in the document I shared as well
4) Enable sip-ua for external registrar (required by external registrar CUCM)
 sip-ua
Note:
  • The CLI is to enable SIP gateway to register E.164 numbers of analog telephone voice ports (FXS) and IP phones virtual voice ports (EFXS) with an external SIP proxy or registrar server.
  • Depending on the gateway type (SIP vs. MGCP) configured on CUCM, the SRST router may or may not need this configuration.
Deepak
Thanks Deepak,
One last query, should i have to configure any dial peer "voip" and "POTS"for SIP Phones ??
Deepak
Deepak
