07-13-2017 11:40 PM - edited 03-17-2019 10:47 AM
Good morning, I'm trying to configure the SRST for sip phones.
I've configured srst on CUCM side, and the following there is a configuration on the router:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice register global
mode srst
max-dn 100
max-pool 50
dialplan-pattern 1 0039880077311 extension-length 3 extension-pattern 814
dialplan-pattern 2 003988007731.. extension-length 3 extension-pattern 8..
voice register pool 1
id network 192.168.2.0 mask 255.255.255.0
dtmf-relay rtp-nte sip-kpml
voice-class codec 1
It's correct or need to configure somethings other?
07-13-2017 11:51 PM
Compare it with below
https://supportforums.cisco.com/document/12746456/how-implement-cisco-unified-sip-srst
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-survivable-remote-site-telephony/201114-SIP-Phones-do-not-Register-to-SRST-route.html
(Rate if it helps)
JB
07-14-2017 01:11 AM
Hi thanks for help.
I've configured all as suggested. Now I cannot check the srst now but with command show ccsip messages I cann see on the phone 8831 that will attempt for registratiorn. All phones 8841, 8851, 8861 eill not attempt to register.
Can you help me to solve?
