SRST881 FXO Port (UK) - phone keeps disconnecting during ringing
jason.henderson
Hi all,
I have this issue with an FXO port where if i make an inbound call to the port, the IP phone rings for less than a second, cuts off, rings for less than a second, cuts off, and so on.  On the mobile i'm making the call from, it sounds fine.
Config i have at the moment is -
voice-port 4
translation-profile incoming Inbound_Call
translation-profile outgoing Outbound_Call
cptone GB
impedance complex3
description *** PSTN Fallback ***
caller-id alerting line-reversal
I can't find anything online describing this issue - could it be something to do with the BT wall socket being either a master or a secondary, or a supervisory-disconnect issue?
Thanks in advance,
Jason
Jason,
010050: *Nov 25 15:17:40.396 GMT: htsp_process_event: [4, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
JMHRAY-VG01#
010051: *Nov 25 15:17:40.396 GMT: htsp_timer2 - 1000 msec
010052: *Nov 25 15:17:40.396 GMT: htsp_timer_stop
010053: *Nov 25 15:17:41.396 GMT: htsp_process_event: [4, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
010054: *Nov 25 15:17:41.396 GMT: htsp_timer_stop
010055: *Nov 25 15:17:41.396 GMT: htsp_timer_stop2
010056: *Nov 25 15:17:41.396 GMT: [4] set signal state = 0x4 timestamp = 0
010057: *Nov 25 15:17:41.396 GMT: //185/00FD1AFE1000/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x868B0B70, Call Id=185
It appears that there is no dial tone on the line
Can you check that a POTS phone works on the wiring.
Can you also make sure that the wiring is correct
FXO --RJ11 ---3 -------  BT PSTN JACK  2
FXO --RJ11 ---4 -------  BT PSTN JACK  5
You must make sure that these are the only wires connected.
Also try a pair reversal
Alex
Regards, Alex. Please rate useful posts.
9 Replies 9
acampbell
Jason,
Can you change the voice port
voice-port 4
no caller-id alerting line-reversal
caller-id enable
caller-id alerting dsp-pre-alloc
supervisory disconnect dualtone mid-call
Let us know if this helps
Alex
Hi Alex,
Tried the above, still not working.  Config is below -
voice-port 4
cptone GB
impedance complex3
description *** PSTN Fallback 020 7235 1623 ***
caller-id alerting dsp-pre-allocate
sh voice port 4
Foreign Exchange Office 4 Slot is 0, Sub-unit is 3, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is *** PSTN Fallback ***
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Power Denial Disconnect Time Out is set to 1000 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for GB
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to complex3 Ohm
Station name None, Station number None
Caller ID Info Follows:
Standard ETSI
DSP is pre-allocated
Translation profile (Incoming): Inbound_Call
Translation profile (Outgoing): Outbound_Call
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is enabled
Number Of Rings is set to 1
Supervisory Disconnect is dualtone mid-call
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnect Timing (loopStart only) is set to 350 ms
OPX Ring Wait Timing is set to 6000 ms
Jason
Jason,
Normally we need to use PLAR to direct the call to a specified number.
I do not see any PLAR here
What does the Translation profile (Incoming): Inbound_Call
contain
Alex
Hi Alex,
See below.  4004 is an internal extension i'm using for testing, but the PSTN line is supposed to be for local 999 breakout, so incoming working is not essential.
In CUCM, i have a route group configured to send any emergency numbers to the 881, but when i try an outbound call i get a Disconnect Cause=34, which i believe means no cct/channel available.  Some debug below as well -
sh deb
CCAPI:
  debug voip ccapi error call is ON (filter is OFF)
  debug voip ccapi error software is ON
  debug voip ccapi inout is ON (filter is OFF)
Voice Port Module signaling debugging is on
010013: *Nov 25 15:17:40.136 GMT: //-1/00FD1AFE1000/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Office
   ----- ccCallInfo IE subfields -----
   cisco-ani=4004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=9123
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
010014: *Nov 25 15:17:40.136 GMT: //-1/00FD1AFE1000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x863795A8, Call Info(
   Calling Number=4004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9123(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=184
010015: *Nov 25 15:17:40.136 GMT: //-1/00FD1AFE1000/CCAPI/ccCheckClipClir:
   In: Calling Number=4004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
010016: *Nov 25 15:17:40.136 GMT: //-1/00FD1AFE1000/CCAPI/ccCheckClipClir:
   Out: Calling Number=4004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
010017: *Nov 25 15:17:40.140 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010018: *Nov 25 15:17:40.140 GMT: :cc_get_feature_vsa malloc success
010019: *Nov 25 15:17:40.140 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010020: *Nov 25 15:17:40.140 GMT:  cc_get_feature_vsa count is 1
010021: *Nov 25 15:17:40.140 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010022: *Nov 25 15:17:40.140 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:2264524184,feature_id:184
010023: *Nov 25 15:17:40.140 GMT: //184/00FD1AFE1000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=4004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9123(TON=Unknown, NPI=Unknown))
010024: *Nov 25 15:17:40.140 GMT: //184/00FD1AFE1000/CCAPI/cc_process_call_setup_ind:
   Event=0x8686EED0
010025: *Nov 25 15:17:40.140 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9123
010026: *Nov 25 15:17:40.140 GMT: //184/00FD1AFE1000/CCAPI/ccCallSetContext:
   Context=0x84F424B4
010027: *Nov 25 15:17:40.140 GMT: //184/00FD1AFE1000/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 184 with tag 1 to app "_ManagedAppProcess_Default"
010028: *Nov 25 15:17:40.140 GMT: //184/00FD1AFE1000/CCAPI/ccCallProceeding:
010029: *Nov 25 15:17:40.140 GMT: //184/00FD1AFE1000/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=9, Params=0x84F433C4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
010030: *Nov 25 15:17:40.144 GMT: //184/00FD1AFE1000/CCAPI/ccCheckClipClir:
010031: *Nov 25 15:17:40.144 GMT: //184/00FD1AFE1000/CCAPI/ccCheckClipClir:
010032: *Nov 25 15:17:40.144 GMT: //184/00FD1AFE1000/CCAPI/ccCallSetupRequest:
   Destination Pattern=9T, Called Number=123, Digit Strip=TRUE
010033: *Nov 25 15:17:40.144 GMT: //184/00FD1AFE1000/CCAPI/ccCallSetupRequest:
   Called Number=123(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=
   Account Number=Office, Final Destination Flag=TRUE,
   Guid=00FD1AFE-8BB0-F1EC-1000-12010A05050E, Outgoing Dial-peer=9
010034: *Nov 25 15:17:40.144 GMT: //184/00FD1AFE1000/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=4004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=123
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
010035: *Nov 25 15:17:40.144 GMT: //184/00FD1AFE1000/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x868B0B70, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=4004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=123(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=9, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
010036: *Nov 25 15:17:40.144 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010037: *Nov 25 15:17:40.144 GMT: :cc_get_feature_vsa malloc success
010038: *Nov 25 15:17:40.144 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010039: *Nov 25 15:17:40.144 GMT:  cc_get_feature_vsa count is 2
010040: *Nov 25 15:17:40.144 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010041: *Nov 25 15:17:40.144 GMT: :FEATURE_VSA attributes are: feature_name:0,feature_time:2264523960,feature_id:185
010042: *Nov 25 15:17:40.144 GMT: //185/00FD1AFE1000/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
010043: *Nov 25 15:17:40.144 GMT: //185/00FD1AFE1000/CCAPI/ccCallSetContext:
   Context=0x84F43374
010044: *Nov 25 15:17:40.144 GMT: //184/00FD1AFE1000/CCAPI/ccSaveDialpeerTag:
010045: *Nov 25 15:17:40.144 GMT: htsp_timer_stop3 htsp_setup_req
010046: *Nov 25 15:17:40.144 GMT: htsp_process_event: [4, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
010047: *Nov 25 15:17:40.144 GMT: [4] set signal state = 0xC timestamp = 0
010048: *Nov 25 15:17:40.148 GMT: htsp_timer - 1300 msec
010049: *Nov 25 15:17:40.148 GMT: //185/00FD1AFE1000/CCAPI/cc_api_call_proceeding:
   Interface=0x868B0B70, Progress Indication=NULL(0)
JMHRAY-VG01#
010058: *Nov 25 15:17:41.396 GMT: //185/00FD1AFE1000/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
010059: *Nov 25 15:17:41.396 GMT: //184/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
010060: *Nov 25 15:17:41.396 GMT: //185/00FD1AFE1000/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=185
010061: *Nov 25 15:17:41.396 GMT: //185/00FD1AFE1000/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
010062: *Nov 25 15:17:41.396 GMT: //185/00FD1AFE1000/CCAPI/ccCallDisconnect:
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
010063: *Nov 25 15:17:41.396 GMT: htsp_process_event: [4, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
010064: *Nov 25 15:17:41.400 GMT: //185/00FD1AFE1000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x868B0B70, Tag=0x0, Call Id=185,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
010065: *Nov 25 15:17:41.400 GMT: //185/00FD1AFE1000/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
010066: *Nov 25 15:17:41.400 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
010067: *Nov 25 15:17:41.400 GMT: :cc_free_feature_vsa freeing 86F9E4B0
010068: *Nov 25 15:17:41.400 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
010069: *Nov 25 15:17:41.400 GMT:  vsacount in free is 1
010070: *Nov 25 15:17:41.400 GMT: //184/00FD1AFE1000/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
010071: *Nov 25 15:17:41.400 GMT: //184/00FD1AFE1000/CCAPI/ccCallDisconnect:
010072: *Nov 25 15:17:41.400 GMT: //184/00FD1AFE1000/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
010073: *Nov 25 15:17:41.404 GMT: //184/00FD1AFE1000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x863795A8, Tag=0x0, Call Id=184,
010074: *Nov 25 15:17:41.404 GMT: //184/00FD1AFE1000/CCAPI/cc_api_call_disconnect_done:
010075: *Nov 25 15:17:41.404 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
010076: *Nov 25 15:17:41.404 GMT: :cc_free_feature_vsa freeing 86F9E590
010077: *Nov 25 15:17:41.404 GMT: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
010078: *Nov 25 15:17:41.404 GMT:  vsacount in free is 0
voice translation-rule 30
rule 1 /^$/ /4004/
voice translation-rule 40
rule 1 /^1/ /901/
rule 2 /^2/ /902/
rule 3 /^3/ /903/
rule 4 /^4/ /904/
rule 5 /^5/ /905/
rule 6 /^6/ /906/
rule 7 /^7/ /907/
rule 8 /^8/ /908/
rule 9 /^9/ /909/
voice translation-profile Inbound_Call
translate calling 40
translate called 30
Jason,
JMHRAY-VG01#
Alex
Cannibalised the RJ11-BT wiring, and it's now working...  Thanks!!!
So if i'm buying the correct RJ11 - BT male wire, what am i looking for?
Cheers
Jason
Jason
I normally use any old RJ11 cord , cut off the other end and Krone the wires from Rj11 3 & 4 (ONLY)
on to the BT wiring 2 & 5 in a jack.
In bigger offices etc the FXO lines appear on the Krone strip or an RJ45 panel
Another note is if it is RJ45 then the pair should be on RJ45 -4 & 5 (Usually the blue/blue-white)
Alex
I have a simple question, the 881SRTS router can be register with a CUCM 7 and work has a remote gateway (SCCP,MGCP or H323) with FXO lines ?
Looks like you are correct
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/overview.html
Voice Features
The Cisco 880 voice and data platforms (C880SRST, C880SRSTW, C881-V, C887 VA-V, and C887VA-V-W) support the following voice features:
Signaling protocols: Session Initiation Protocol (SIP), Media Gateway Control Protocol (MGCP), and H323
Real-time transfer protocol (RTP), Cisco RTP (cRTP), and secure RTP (SRTP) for these signaling protocols
Fax passthrough, Cisco fax relay, T37 fax store-and-forward, and T.38 fax relay (including T.38 gateway-controlled MGCP fax relay)
Dual tone multifrequency (DTMF) Relay—OOB and RFC2833
Silence suppression/comfort noise
G.711 (a-law and u-law), G.729A, G.729AB, G.729, G.729B, G.726
Support of SRST failover to a Foreign Exchange Office (FXO) or BRI backup port connected to PSTN in case of WAN failure on C880SRST and C880SRSTW.
Support for SRST and CME requires user license, but only a 5-user license is supported on C881-V, C887VA-V, and C887VA-V-W routers.
Direct inward dialing (DID) on FXS
Alex
