SSO enabled on collab edge and MRA IP phones
viraj0raut
Beginner
Beginner
We have a deployment for Collaboration Edge where customer want to enable SSO. That's fine for Jabber.
Customer has 7800/8800 IP phones, DX series and the SX series that are being used today as MRA devices, will they work ok?
Is there a signaling flow diagram that can clarify how user authentication id done when using these devices with SSO enabled on collaboration edge?
Thanks in advance.
Kevin Roarty
Yes, the non-SSO enabled devices will continue to work using the same authentication they have always used.
Recognize Your Peers
