Strange DN behaiviour
Operepichay
Two DN's are in same partition and with same CSS.
352 DN is unable to call some destinations (fast busy) and 312 DN calls with no problems.
Phone change had no luck. When I change DN from 352 to 351 all works fine.
352 DN was created some time before and had no such problems.
352 DN has also problems with calls to some other internal DNs.
Logs are in attachments (call to number 0661234567)
Jaime Valencia
Without knowing the call flow, it seems the other end is rejecting the call, did you review the traces????
2016/10/10 17:10:20.628|CC|SETUP|31088991|31088992|352|0661234567|0661234567
2016/10/10 17:10:20.648|CC|OFFERED|31088991|31088992|352|0661234567|0661234567|SEP000F341294EB|ASTERISK
2016/10/10 17:10:20.649|SIPT|31088992|UDP|OUT|10.1.2.60|5060|ASTERISK|10.1.31.70|5060|1,100,14,92.15945^10.1.2.60^MTP|592618|45bc7380-7fb1a14c-34ec-3c02010a@10.1.2.60|INVITE
2016/10/10 17:10:20.651|SIPT|31088992|UDP|IN|10.1.2.60|5060|ASTERISK|10.1.31.70|5060|1,100,10,1.224463^10.1.31.70^*|592619|45bc7380-7fb1a14c-34ec-3c02010a@10.1.2.60|401 Unauthorized
2016/10/10 17:10:20.651|SIPT|31088992|UDP|OUT|10.1.2.60|5060|ASTERISK|10.1.31.70|5060|1,100,10,1.224463^10.1.31.70^*|592620|45bc7380-7fb1a14c-34ec-3c02010a@10.1.2.60|ACK
java
if this helps, please rate
Aseem Anand
Can you share the model details tested, CUCM version with along with the Call manager SDL traces?
It could be an issue with the dbreplication. Also, check the output of the command below:
utils dbreplication runtimestate
utile dbreplication status
Aseem
Jaime Valencia
java
There was same DN registered at Asterisk.
