strange issue outgoing call with multiple ISDN BRI
Support Albakom
Level 3
Level 3
we configured an CUCM 8.5 and an H323 Gateway Cisco 2821.
At the gateway I installed 3 BRI two port cards, also I have six ISDN BRI voice ports.
I configured overlap sending at callmanager and gateway.
I configured 6 dial-peers POTS with destination-pattern 0. (Germany) for outgoing calls. Each dial-peers has one of the ISDN as port.
forward-digit is default.
I connect only one of the 6 ISDN ports to simulate that th others not working or busy.
I dial from a phone e.g. 0012345678.
I see in debug isdn q931 like the gateway search for a good isdn. If it found the working one it sends out the call, but not as
012345678, but as 12345678. So theres a wrong number goes to PSTN.
It look like the gateway takes POTS peer with best preference, strip the "0" (destination-pattern 0.) and route to ISDN-Port. Theres no connection(down), so it comes back and try the next one dial-peer, without reassemble the called number.
IOS is c2800nm-spservicesk9-mz.150-1.M3.bin.
Can somebody help?
acampbell
Can you try
diail-peer voice xxx pots
dest 00T
prefix 0
Alex
Regards, Alex. Please rate useful posts.
Hi.
Please can post your actual config and the output of a debug isdn q931? I tried the same in a lab and the behaviour in my lab  is correct as the VG sends out all digits as they were dialed.
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
