Sub interfaces on a interface
John Cheetley
Level 3
Level 3
Hi Techs,
Am aware that you can have up to so many sub interfaces on a interface based on link below
https://learningnetwork.cisco.com/thread/65242
What is the purpose of this when for access list purposes, you must have 2 separate interfaces.
One for internal for devices(whether computer or IP phones) and one external for internet access
I am confused..
As I have configured FA0/0 to 192.168.0.1
This has 2 sub interfaces of FA0/0.1 (192.168.1.2 ) and FA0/0.2 to (192.168.2.2) with phones off this address and router ip of 192.168.0.12
I was going to use 192.168.1.2 as outside LAN and 192.168.2.2 as inside LAN for access list purpose
Thanks again :) :)
iMedxSGower
If you are using Gigabit Ethernet, you can apply an ACL directly to a sub-interface.  Unfortunately, in your example, you're using Fast Ethernet, which does not support this usage, so any ACL has to be applied at the physical level and thus affects all the sub-interfaces equally.   Your plan will need revision.
