Subscribe extension mobility for registered phones
Syed
Level 3
Level 3
Dear All,
I have 400 phones already registered with cucm.
My requirement is to subscribe these phones with extension mobility service using BAT.
I have referred the below link but it is not very clear to me.
Can this be achieved without removing phones from CUCM?
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-60/112009-em-bat-config.html
Syed
sanjaydevan
If all of these phones are of same model, you can create a phone template and subscribe the the services to it. Later you can apply this template to the phones in update phones > query or custom file.
Devan
Rate useful posts!
sanjaydevan
Devan
Rate useful posts!
I missed assign ip phone services part.
Appreciate you quick help & support, Devan.
Thank you
Jaime Valencia
Delete the EM service, create it again, and choose enterprise subscription.
java
if this helps, please rate
Hi Jaime,
I have 6500 phones on this cluster depending upon this service, is it okay if I delete and recreate?
