T1/PRI
osamaokok
I am trying to implement T1/PRI using my 2611xm router connected to MC3800 as PBX.
my problem is that there is no ds0-group in the controller T1 0/1, my ios ver is C2600-SPSERVICESK9-M), Version 12.4(17)
and i had VWIC2-2MFT-T1/E1 installed on the router.
regards
You don't have any DSP's to support the T1 interface. The voice card in slot 1 can only be used with the analogue voice ports installed locally on the network module.
To make the T1 work, you will need an AIM-VOICE-30 module that clips onto the motherboard socket of the router -
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_data_sheet09186a0080088753.html
If you get one, don't forget to add these commands to make it work properly -
network-clock-participate aim 0
network-clock-select 1 t1 0/1
8 Replies 8
swensonj
Try "pri-group ?" rather than "ds0-group ?"
Thanks for your response,
pri-group also is not showing, only channel-group and tdm-group.
do you have DSPs to use that card???
javalenc
if this helps, please rate
java
how to know that ??
do a sh diag
javalenc
java
mgcp-gw#sh diag
WIC Slot 1:
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC1147691L
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 31 34 37 36 39 31 4C 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
here is my sh diag and sh ver
