12-29-2008 04:14 AM - edited 03-15-2019 03:15 PM
Hi ,
Can any one help me to take the back up of IP phone details and corresponding
DN to excel sheet for the sake of inventory in UCCM : 6.0 .
Thanks & Regards ,
sinjish.K
01-02-2009 12:40 PM
The Cisco IP telephony Applications Backup Utility automatically backs up the following items:
⢠Cisco CallManager database on SQL Server 7, including the Call Detail Records (CDR) database
⢠Administrative Reporting Tool (ART) database
⢠DC Directory, LDAP directory
⢠Distribution .ini, which contains the publisher and subscriber configuration information
⢠Database.dat, if present
⢠HKLM\Software\Cisco Systems, Inc.
⢠Cisco Customer Response Applications (CRA)
For detailed information on backing up the Cisco CallManager, refer to the Backing Up and Restoring Cisco CallManager and locate your release number at the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/
01-02-2009 01:17 PM
BARS is not used on linux appliances, you use DRS
Disaster Recovery System Administration Guide for Release 6.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_0_1/drs/drsag601.html
java
if this helps, please rate
