Taking the Backup of Call Manager Directory
k_sinjish
Hi ,
Can any one help me to take the back up of IP phone details and corresponding
DN to excel sheet for the sake of inventory in UCCM : 6.0 .
Thanks & Regards ,
sinjish.K
carenas123
Level 5
Level 5
The Cisco IP telephony Applications Backup Utility automatically backs up the following items:
• Cisco CallManager database on SQL Server 7, including the Call Detail Records (CDR) database
• Administrative Reporting Tool (ART) database
• DC Directory, LDAP directory
• Distribution .ini, which contains the publisher and subscriber configuration information
• Database.dat, if present
• HKLM\Software\Cisco Systems, Inc.
• Cisco Customer Response Applications (CRA)
For detailed information on backing up the Cisco CallManager, refer to the Backing Up and Restoring Cisco CallManager and locate your release number at the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/
BARS is not used on linux appliances, you use DRS
Disaster Recovery System Administration Guide for Release 6.0(1)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_0_1/drs/drsag601.html
java
if this helps, please rate
java
