Tape Drive For CUCM Backup
Hi, I have callmanager 7.1.5 and I have HP usb tape drive supplied from Cisco , I would like to know the steps to add the tape drive to the call manager so that i can use it for the Backups.
Best regards.
7 Replies 7
Jaime Valencia
Disaster Recovery System Administration Guide for Release 7.1(2)
Or you can just go into your server and use the help -> for this page menu to get the info.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hello
thanks for your answer.but in my case when I want to add the tape deviece no tape devieces apperin the list.how to add the tape deviece hardware.the tape device is powered up and connected with a USB cable to the PUB server.
ANY HELP ?
Assuming the server detects the tape drive which can be confirmed from the CLI with "show tech system bus".  Then to add the tape drive as the backup destination go to the DRS/DRF page Backup > Backup Device.  Add New > Select tape device and select it from the list.  Now when doing backups you should be able to select the tape drive as the destination.
thanks Joe
Dose the server detect the tape drive by it self I mean no need for defination driver file or such a thing becouse when I go the DRS/DRF I do not find any backup device listed to chose.
Any One Could Advice
Since it is USB it should automatically be detected.  However if the drive isn't on the supported list of tape drives for the server/CUCM version, it may not work.
