IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 1226 Views
  • 6 replies
Hi All, I am trying to run setup wizard in cisco UMG on a 2911 router and have few questions1. When trying to add a voicemail or CM server using ip address it errors with Hostname not found in DNS, does this means DNS is mandatory if not do i then go...
Hi,please help me with ssh issues.I just upgraded my Cisco IP Phone 7962 and 7975 to SIPxx-9-2-1S firmware.I can't access the phones via ssh or telnet.In SEP<mac>.cnf.xml are defined "sshUserId" and "sshPassword" fields.How fix it?Thanks in advance.
    I am trying to understand CUBE from the perspective of when you need it and when you don't. For example, I  am looking at a configuration that is used by a Avaya PBX that has a pri connection to a router which then has a sip-ua connection to Paet...
whanson by Explorer
  • 701 Views
  • 4 replies
                   Hi all,customer of mine has this old version of CUCMCall Manager 1000 USER1MCS-7825I-3.0-IPC1HW Only MCS 7825I-3000 With P4 3060, 1GB RAM, 80GB HD1CAB-ACIPower Cord-Italian2KEY-CCM-ADMIN-K9=Hardware Security Key for CCM Admin, Rele...
hello,does anyone know if peer firmware sharing is as a feature accessible for 69xx devices? i've found an info, that SIP firmware release 9.1(1) includes this feature, but what about sccp firmware? even in cucm 8.6 there is no option under device co...
Dear NetPro gurus,I notice on the Cisco CallManager's Route Pattern, i can set different types of symbols other than X or numerical numbers.Can someone please kindly explain to mean what are the differences between the following symbols and would be ...
happyatuni by Beginner
  • 1275 Views
  • 4 replies
Hi Everybody,I'm now using CUCM 8.6 with a publisher and a subscriberNow the publisher is crash and need to be installed again.Is there anything I need to be aware, or just install as normal and restore the CUCM backup?Thanks in advanceSam
