06-08-2012 06:25 AM - edited 03-16-2019 11:34 AM
Hello every body, I have an issue with a tcl script.
I have created a script to play a welcome prompt on the incoming dial peer on a Cisco Gateway.
When a user with a voip phone or a gsm try to call a number behind the gateway, everything is fine the number entirely sended, the promt is played and the call goes out the gateway to the call manager.
When a user with a phone behind an old analog line try to call, the prompt is not played and we have a busy tone before we have dialed the last two digit.
I think it's the overlap which is not working fine because the script try to start before the gateway have collected the entire number but I do not know how to fix it.
Here is the configuration of the incoming dial peer :
dial-peer voice 102 pots
trunkgroup 1
description CALL_INCOMING_FROM_PSTN_POTS
incoming called-number .T
service annonce
direct-inward-dial
Here is the outgoing dial peer to the CUCM:
dial-peer voice 202 voip
  description CALL_OUTGOING_TO_CUCM
destination-pattern .T
  progress_ind setup enable 3
  voice-class codec 1
  voice-class h323 1
  session target ipv4:172.16.211.11
  dtmf-relay h245-alphanumeric
  ip qos dscp cs3 signaling
  no vad
Here is the script :
proc init_configs { } {
global welcomePrompt
if [infotag get cfg_avpair_exists welcome-prompt] {
setwelcomePrompt [string trim [infotag get cfg_avpair welwome-prompt]]
} else {
set welcomePrompt flash:bcpannonce2.wav
#procedure to play audio file on incoming dial peer
proc act_Media { } {
global dest
set dest [infotag get leg_dnis]
leg setupack leg_incoming
leg proceeding leg_incoming
leg connect leg_incoming
media play leg_incoming $welcomePrompt
# setup the call, connect caller to called party
proc act_Setup { } {
global dest
puts ">>> Tcl: proc act_Setup <<<"
puts ">>> TCL:Final Dest: $dest <<<"
handoff appl leg_incoming default "DESTINATION=$dest"
act_Cleanup
# disconnect the call
proc act_Cleanup { } {
puts ">>> Tcl: act_Cleanup <<<"
call close
init_configs
set fsm(any_state,ev_disconnected) "act_Cleanup same_state"
set fsm(CALL_INIT,ev_setup_indication) "act_Media PLAYPROMPT"
set fsm(PLAYPROMPT,ev_media_done) "act_Setup PLACECALL"
set fsm(PLACECALL,ev_disconnected) "act_Cleanup CALLDISCONNECT"
set fsm(CALLDISCONNECT,ev_disconnected) "act_Cleanup same_state"
set fsm(CALLDISCONNECT,ev_media_done) "act_Cleanup same_state"
set fsm(CALLDISCONNECT,ev_disconnect_done) "act_Cleanup same_state"
fsm define fsm CALL_INIT
And here is the debug when the analog line try to call a phone behind the gateway:
.Jun 7 17:11:36: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x00A3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '2'
Plan:ISDN, Type:Unknown
.Jun 7 17:11:36: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=4040222, Voice-Interface=0x45D0C528,
Timeout=FALSE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=NO_MATCH(-1) After All Match Rules Attempt
Calling Number=, Called Number=4040222, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=102
.Jun 7 17:11:36: ISDN BR0/0/1 Q931: TX -> SETUP_ACK pd = 8 callref = 0x81
Channel ID i = 0x89
.Jun 7 17:11:36: //-1//SERV:/AFW_Service_CCInterface: Received Event 24 for service annonce modulehandle NULL
.Jun 7 17:11:36: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = annonce
.Jun 7 17:11:36: //-1//AFW_:/AFW_Process_New: annonce
.Jun 7 17:11:36: //-1//AFW_:/AFW_ExecEnv_New:
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/AFW_ExecEnv_SetRoot: Execenv = 0x45929EF8
.Jun 7 17:11:36: //-1//AFW_:/AFW_TclModule_New:
.Jun 7 17:11:36: //-1//AFW_:/AFW_Process_Lock: pProcess(0x4668030C)=1
.Jun 7 17:11:36: //-1//AFW_:LP:EE45929EF8000:HN25CBE4AC:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/AFW_ExecEnv_SetScript: Script Name = annonce,
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/AFW_ExecEnv_SetScript: Script URI = flash:annoandforw3.tcl
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/Tcl_Link: Linking script annonce
.Jun 7 17:11:36: //-1//ACPK:EE45929EF8000:/AppCommon_SetSecurity: security = undefined
.Jun 7 17:11:36: //-1//ACPK:EE45929EF8000:/AppCommon_SetEventLog: event-log = unconfigured
.Jun 7 17:11:36: //-1//PACK:/CMeth_Httpios_Main: Main Executing
.Jun 7 17:11:36: //-1//TCL2:/Package_Tcl20Base_Load_Language:
.Jun 7 17:11:36: //-1//TCL :EE45929EF8000:/tcl_InfotagObjCmd: infotag get cfg_avpair_exists welcome-prompt
.Jun 7 17:11:36: //-1//TCL :EE45929EF8000:/tcl_InfotagGetObjCmd: infotag get cfg_avpair_exists welcome-prompt
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/vtr_cf_avpair_exists: argc 3 argindex 2
.Jun 7 17:11:36: //-1//TCL :EE45929EF8000:/tcl_FSMObjCmd: fsm define fsm CALL_INIT
.Jun 7 17:11:36: //-1//AFW_:/AFW_FSM_New:
.Jun 7 17:11:36: //-1//TCL :EE45929EF8000:/tcl_FSMDefineObjCmd: State Machine: Array fsm: Start State: CALL_INIT
.Jun 7 17:11:36: //-1//TCL :EE45929EF8000:/tcl_FSMDefineObjCmd: FSM Data structure
.Jun 7 17:11:36: (CALLDISCONNECT(2), ev_media_done(136)--(act_Cleanup)-->(any_state(0))
.Jun 7 17:11:36: (any_state(0), ev_disconnected(16)--(act_Cleanup)-->(any_state(0))
.Jun 7 17:11:36: (PLACECALL(3), ev_disconnected(16)--(act_Cleanup)-->(CALLDISCONNECT(2))
.Jun 7 17:11:36: (CALLDISCONNECT(2), ev_disconnect_done(17)--(act_Cleanup)-->(any_state(0))
.Jun 7 17:11:36: (CALLDISCONNECT(2), ev_disconnected(16)--(act_Cleanup)-->(any_state(0))
.Jun 7 17:11:36: (PLAYPROMPT(4), ev_media_done(136)--(act_Setup)-->(PLACECALL(3))
.Jun 7 17:11:36: (CALL_INIT(1), ev_setup_indication(29)--(act_Media)-->(PLAYPROMPT(4))
.Jun 7 17:11:36: FSM start state CALL_INIT(1)
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/Tcl_Link: Script annonce succesfully linked.
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/AFW_ExecEnv_SetScript: Num of packTable entries: 26
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/AFW_ExecEnv_Initiate: Execenv = 0x45929EF8
.Jun 7 17:11:36: //-1//AFW_:/AFW_Leg_New:
.Jun 7 17:11:36: //76628//AFW_:/AFW_M_Leg_SetExecEnv:
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/AFW_ExecEnv_IncrPendingCmd: PendingCmdCount: 1
.Jun 7 17:11:36: //-1//AFW_:LP:EE45929EF8000:LG76628:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1
.Jun 7 17:11:36: //76628//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_76628
.Jun 7 17:11:36: //-1//AFW_:EE45929EF8000:/AFW_ExecEnv_AssignCall: Execenv = 0x45929EF8, Leg = 76628, Peer_Tag = 102
.Jun 7 17:11:36: //-1//SERV:/AFW_Service_Process_Space:
.Jun 7 17:11:36: Process Started
.Jun 7 17:11:36: //-1//AFW_:/AFW_Process_Register: ccAppInitialize(name: _ManagedAppProcess_annonce)
.Jun 7 17:11:36: //-1//AFW_:/AFW_Event_New:
.Jun 7 17:11:36: //76628//AFW_:/AFW_Process_GetCcqEvent: Received
.Jun 7 17:11:36: //-1//AFW_:/AFW_Process_GetCcqEvent: Event[CC_EV_CALL_SETUP_IND(29)] {
.Jun 7 17:11:36: //-1//AFW_:/AFW_Process_GetCcqEvent: EXECENV[0x45929EF8][annonce]
.Jun 7 17:11:36: //-1//AFW_:/AFW_Process_GetCcqEvent: LEG[76628][LEG_INIT(0)][Cause(0)]
.Jun 7 17:11:36: //-1//AFW_:/AFW_Process_GetCcqEvent: }
.Jun 7 17:11:36: //76628//SSIN:/AFW_SS_MapEvent:
.Jun 7 17:11:36: //76628//AFW_:/AFW_Leg_GetTypeDetail: invalid interface
.Jun 7 17:11:36: //-1//SSIN:/AFW_SS_Telephony_MapEvent:
.Jun 7 17:11:36: //-1//AFW_:/AFW_Util_SaveRawMsg:
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 9695 type 0
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Object_WalkListeners:
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_M_Object_ShowListeners: START
.Jun 7 17:11:36: //-1//AFW_:/AFW_M_Object_ShowListeners:
.Jun 7 17:11:36: //76628//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_46686354_14_634119340MOD[TclModule_46686354_14_634119340 ] (
.Jun 7 17:11:36: //-1//AFW_:/AFW_M_Object_ShowListeners: LEG[76628][LEG_INCINIT(1)][Cause(0)]
.Jun 7 17:11:36: //-1//AFW_:/AFW_M_Object_ShowListeners: )
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_M_Object_ShowListeners: END
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
.Jun 7 17:11:36: //76628//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_46686354_14_634119340 ---> TclModule_46686354_14_634119340
.Jun 7 17:11:36: //76628//AFW_:/AFW_M_TclModule_Action:
.Jun 7 17:11:36: //76628//AFW_:/AFW_TclModule_DefaultEvHandling:
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_CheckIncomingCallBlock:
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_IncomingCallBlock: type=0,profile=0x460DC248
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_IncomingCallBlock: cllng() clld(4040222) redirect()
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_IncomingCallBlock: xrule:org_num() type(0) plan(0)
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_IncomingCallBlock: type=1,profile=0x460DC248
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_IncomingCallBlock: xrule:org_num(4040222) type(0) plan(1)
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_IncomingCallBlock: type=2,profile=0x460DC248
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_IncomingCallBlock: xrule:org_num() type(-1) plan(-1)
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_SettlementValidateCall: target=, tokenp=0x0
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_IncomingTranslate:
.Jun 7 17:11:36: //76628//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(CALL_INIT[1],ev_setup_indication[29])---[act_Media]------
.Jun 7 17:11:36: //76628//TCL :/tcl_InfotagObjCmd: infotag get leg_dnis
.Jun 7 17:11:36: //76628//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
.Jun 7 17:11:36: //76628//AFW_:/vtr_lg_dnis: argc 2 argindex 2
.Jun 7 17:11:36: //76628//TCL :/tcl_LegObjCmd: leg setupack leg_incoming
.Jun 7 17:11:36: //76628//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
.Jun 7 17:11:36: //76628//AFW_:/vtd_lg_incoming: argc 2
.Jun 7 17:11:36: //76628//AFW_:/vtd_lg_incoming: Legs [76628 ]
.Jun 7 17:11:36: //76628//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
.Jun 7 17:11:36: //76628//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
.Jun 7 17:11:36: TCL script failure
Result:
Illegal Operation: Leg not incoming or in wrong state
.Jun 7 17:11:36: TCL script failure errorInfo:
while executing
"leg setupack leg_incoming
(procedure "act_Media" line 7)
invoked from within
"act_Media"
.Jun 7 17:11:36: //76628//AFW_:/AFW_FSM_Drive: ACTION END: -------------(PLAYPROMPT[4])---------------
.Jun 7 17:11:36: //-1//AFW_:/AFW_ExecEnv_CallClose: Exec Env state: 1
.Jun 7 17:11:36: //-1//AFW_:/AFW_ExecEnv_CallClose: Terminating ExecEnv's root module
.Jun 7 17:11:36: //76628//AFW_:/AFW_Module_Terminate: Terminating Module: TclModule_46686354_14_634119340
.Jun 7 17:11:36: //76628//AFW_:/AFW_M_TclModule_Terminate: Module is in the state: ACTIVE
.Jun 7 17:11:36: //76628//AFW_:/AFW_TclModule_Cleaner: lastFailureCause 0
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_76628, Cause 16
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 9695 type 2
.Jun 7 17:11:36: //-1//AFW_:/AFW_Instance_DecrRefCount: Object: 0x466B1A64, Type: Event, RefCount: 0
.Jun 7 17:11:36: //76628/4AA30BF4B70C/AFW_:/AFW_M_Event_Free:
.Jun 7 17:11:36: //76628//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
.Jun 7 17:11:36: ISDN BR0/0/1 Q931: TX -> DISCONNECT pd = 8 callref = 0x81
Cause i = 0x8090 - Normal call clearing
.Jun 7 17:11:36: ISDN BR0/0/1 Q931: RX <- INFORMATION pd = 8 callref = 0x01
Sending Complete
Called Party Number i = 0x81, '4'
We tried to call the number 40402224
As you can see, the last digit which is a "4", is collected after the beginning of the application...
Could someone help me please ?
02-06-2013 04:47 AM
Hi Marc,
I am facing the same problem.
Did you resolve this? Care to share? :-)
br,
Trond
02-06-2013 05:46 AM
You must configure the complete incoming called number in DP, so the script is invoked when all digits have been received.
02-06-2013 06:26 AM
Hello TJ,
I resolved this issue by creating a new dial peer beetween the "pstn pots dial peer" and the "CUCM dial peer".
The service which will run the tcl script must be launch on the last dial peer to CUCM.
So I created the dial peer 200 which collect the entire calling number and don't launch the tcl script.
After that, you can translate or manipulate the number to match with the dial peer to the CUCM. In my exemple, I matched and stripped the first 6 digits in dial peer 200, and matched with the 3 last digits in dial peer 300, the annonce will run...
Here is my config :
dial-peer voice 100 pots
trunkgroup 1
call-block translation-profile incoming PROF10
direct-inward-dial
dial-peer voice 300 voip
service annonce
destination-pattern 2..
incoming called-number 2..
dial-peer voice 200 voip
description DIAL-PEER to prevent OVERLAP issue
translation-profile outgoing PROF1
destination-pattern 404022T //that is the root number which I will strip to last 3 digit to match with dial peer 300
session target ipv4:172.16.211.12 //IP Adress of the gateway to loop to the dial peer 300
02-10-2013 11:42 PM
Hi!
Thanks for the answers! For some reason Paolos suggestion did not work, I was not able to get a match with the incoming called-number command. But looping over IP as Marc suggested worked nicely. Needed g711u codec in addition.
br,
Trond
02-22-2013 04:34 AM
Hi, Just wanted to share my final solution to this.
I first got it working doing the loop over IP solution, but the problem was that the next calleg also needed to be g729 sometimes. So to avoid using a transcoder to to this I managed to collect the digits inside the scrips instead, and then removed the need for looping over IP.
I can mail you the script i you want it.
regards,
Trond
05-01-2013 06:32 AM
Trond,
I am trying to do something very similar could you email me the script?
08-22-2016 02:04 AM
Hi Trond,
can you please send us the modified script you've created. We face the same issue as mentioned.
Best regards,
Matt
08-24-2016 03:35 AM
Some years ago now, but I think it is this is the correct one. This accepts call on analogue port, plays amessage, accepts digit input, and forwards the call. You also needs that wav file correctly formatted of course. tcl attached but renamed for upload
good luck!
IOS config:
application
service spillmeldingcollect flash:spillmeldingcollect.tcl
paramspace english index 0
paramspace english language en
paramspace english location flash:
param welcome-prompt flash:ulawtest.wav
dial-peer voice 991 pots
dial-peer voice 990 pots
