IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5865 Views
  • 14 replies
Hello All       User only can answer an incoming call with Speaker. The handle will work after 2-3 minutes if the handle is pick up same time.  The firmware version is sccp41.9-4-2-1S.   There are three Cisco 7941 have same problem. Do you think that...
yuexp0929 by Level 1
  • 649 Views
  • 3 replies
We have Cisco 8861 phone enabled with SNR, and CUCM is v10.5.2 Will it be possible to do like this with SNR? "When you are on a call on 8861 and want to send this call (in conversation) to your mobile, just press a softkey or a button etc and the cal...
Hi Guys, We tried to check if the existing SRST is working and when the IP Phones went to SRST, we tried to call the trunk line number 2400 but the call won't get through. Upon checking the debug, we found disconnection cause or information "Cause i...
