Telepresence System EX 60 endpoint connect to internet
Hi All,
Is't posible to make call to external party on SIP from my EX60 endpoint that connect directly to my home broadband?
Let say my client provide me with the URI address to call, unfortunately i only have the EX 60 system with no VCS or VCSE even no CUCM. Is it posible that i can call to the URI address if i connect directly to my home broadband.
2. If i have EX 60 connect to VCS connect to Internet, is it posible that i can make call to external party?
Experts, please advice.
Many Thanks
Chrysostomos_CY
Level 5
Level 5
I believe that you can set the EX 60 to work as a standalone
In the begining of the setup you can choose the EX to work as a standalone
Then you can dial an external endpoint throught internet without any addtional device(vcs for example)
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
is there any support document that i can refer to configure my ex60 endpoint to work standalone? please advice..
many thanks
Unfortunately i dont have any official doc for that
But its not difficult to setup that
Just choose sip as a protocol , add a public ip into the config , connect tandberg with internet (you must have a public static ip) and then here we are
Is very simple
Try it and if you stuck i will try to help you
