testing Cisco IP phones with remote control
ctr000001
Hi all - We are writing some test programs that need to provision, make/answer calls on a set of different model Cisco VoIP(SIP) phones and are looking for the easiest way to automate this. Are there some references available that can show different ways to accomplish this? Is there a web interface or CLI interface or restful interface available on Cisco phones that can be used to control the phones? Do they support cURL for example?
Many thanks for your guidance in advance.
Chuck
mathewlouis
Level 4
Level 4
You might check out Cisco DevNet for this
https://developer.cisco.com/site/ip-phone-services/overview/
https://developer.cisco.com/fileMedia/download/0d2f0d08-c7a4-48b9-8bc2-0bf69ab27382
Also there are some companies that make programs that do this type of thing...
http://www.unifiedfx.com/products/phoneview/
https://www.singlewire.com/free-xml-apps.html
Ramy Dawoud
please check
http://codingofthings.com/Apps/Index/13
for bulk remote control , you can select multiple phone to control at the same time.
