tftp-ciro15
nettuno8_20111
        hi I have a 2901 router version 15.7 CME 12.0 I have a problem I have 7942 ip phones that I reset them and now they can't get the firmware instead the 7975 ip phones can get the firmware. How come? I attach the tftp debug and the router config. then due to the presence of the IP telephones everything works for me, except that on the IP telephones the presence only works when an IP telephone makes a call and instead when the IP telephone goes into DND I have when it is busy the presence does not work the telephones are registered in SIP        version 15.7
hostname router-voice
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.157-3.M2.bin
boot-end-marker
no aaa new-model
ip dhcp pool data
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 192.168.0.1
ip dhcp pool voip-sip-sccp
network 192.168.15.0 255.255.255.0
default-router 192.168.15.1
option 150 ip 192.168.15.1
ip host ata.com 192.168.15.50
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
voice-card 0
codec complexity high
dspfarm
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 120 min 60
voice register global
mode cme
source-address 192.168.15.1 port 5060
timeouts interdigit 2
max-dn 20
max-pool 20
load 7942 SIP42.9-2-1S
load 7975 SIP75.9-2-3S
timezone 28
time-format 24
date-format D/M/Y
tftp-path flash:
logo CME-SIP
create profile sync 0024965059104819
network-locale IT
user-locale IT
auto-register
voice register dn 1
number 301
allow watch
name anna
label anna
voice register dn 2
number 302
allow watch
name noemi
label noemi
voice register dn 3
number 303
allow watch
name pasquale
label pasquale
voice register dn 4
number 304
allow watch
name ata
label ata
voice register dn 5
number 3005
allow watch
name enzo
label enzo
voice register pool 1
id mac 6416.8DBB.913F
type 7975
number 1 dn 1
presence call-list
dtmf-relay sip-notify
blf-speed-dial 1 302 label "noemi" device
blf-speed-dial 2 402 label "maria" device
blf-speed-dial 3 401 label "ciro" device
blf-speed-dial 4 303 label "pasquale" device
blf-speed-dial 5 304 label "ata" device
voice register pool 2
id mac 001D.45E9.5D43
type 7975
number 1 dn 2
presence call-list
voice register pool 3
id mac 108C.CFE1.3244
type 7942
number 1 dn 3
presence call-list
blf-speed-dial 1 301 label "anna" device
voice register pool 4
id mac 8875.5607.9024
type ATA
number 1 dn 4
presence call-list
voice register pool 5
id mac 805E.C0E4.B6EA
number 1 dn 5
presence call-list
username admin password admin
vxml logging-tag
license udi pid CISCO2901/K9 sn FCZ171691S0
hw-module pvdm 0/0
vtp mode transparent
vtp version 2
redundancy
controller VDSL 0/0/0
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description router-voice to router-isp
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1.15
description VOIP-SIP-SCCP
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
no ip address
shutdown
ip forward-protocol nd
ip http server
no ip http secure-server
ip dns server
ipv6 ioam timestamp
tftp-server flash:apps75.9-2-3TH1-9.sbn
tftp-server flash:cnu75.9-2-3TH1-9.sbn
tftp-server flash:cvm75sip.9-2-3TH1-9.sbn
tftp-server flash:dsp75.9-2-3TH1-9.sbn
tftp-server flash:jar75sip.9-2-3TH1-9.sbn
tftp-server flash:SIP75.9-2-3S.loads
tftp-server flash:term75.default.loads
tftp-server flash:term42.default.loads
tftp-server flash:apps42.9-2-1TH1-13.sbn
tftp-server flash:cnu42.9-2-1TH1-13.sbn
tftp-server flash:cvm42sip.9-2-1TH1-13.sbn
tftp-server flash:dsp42.9-2-1TH1-13.sbn
tftp-server flash:jar42sip.9-2-1TH1-13.sbn
tftp-server flash:SIP42.9-2-1S.loads
tftp-server flash:term62.default.loads
tftp-server flash:SCCP42.8-3-3S.loads
tftp-server flash:jar42sccp.8-3-2-27.sbn
tftp-server flash:dsp42.8-3-2-27.sbn
tftp-server flash:cvm42sccp.8-3-2-27.sbn
tftp-server flash:cnu42.8-3-2-27.sbn
tftp-server flash:apps42.8-3-2-27.sbn
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
presence
presence call-list
max-subscription 150
watcher all
allow subscribe
sip-ua
presence enable
gatekeeper
shutdown
telephony-service
max-ephones 20
max-dn 20
ip source-address 192.168.15.1 port 2000
system message CME-SCCP
user-locale IT
network-locale IT
load 7942 SCCP42.8-3-3S
time-zone 28
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1
number 401
label ciro
name ciro
allow watch
ephone-dn 2
number 402
label maria
name maria
allow watch
ephone 1
device-security-mode none
mac-address C07B.BCA0.99EB
presence call-list
type 7942
button 1:1
ephone 2
mac-address 0016.C7EA.297E
presence call-list
blf-speed-dial 2 302 label "NOEMI" device
type 7960
button 1:2
vstack
line con 0
password ciro
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0
password ciro
logging synchronous
login
transport input telnet
line vty 1 4
login
transport input none
scheduler allocate 20000 1000
end        router-voice#
*Sep 2 16:20:57.555: TFTP: Looking for term42.default.loads
*Sep 2 16:20:57.559: TFTP: Opened flash0:term42.default.loads, fd 10, size 678 for process 125
*Sep 2 16:20:57.559: TFTP: Finished flash0:term42.default.loads, time 00:00:00 for process 125
*Sep 2 16:20:58.875: TFTP: Looking for term42.default.loads
*Sep 2 16:20:58.879: TFTP: Opened flash0:term42.default.loads, fd 10, size 678 for process 125
*Sep 2 16:20:58.879: TFTP: Finished flash0:term42.default.loads, time 00:00:00 for process 125
*Sep 2 16:22:18.131: TFTP: Looking for term75.default.loads
*Sep 2 16:22:18.131: TFTP: Opened flash0:term75.default.loads, fd 10, size 654 for process 125
*Sep 2 16:22:18.135: TFTP: Finished flash0:term75.default.loads, time 00:00:00 for process 125
*Sep 2 16:22:18.883: TFTP: Looking for jar75sip.9-2-3TH1-9.sbn
*Sep 2 16:22:18.883: TFTP: Opened flash0:jar75sip.9-2-3TH1-9.sbn, fd 10, size 1893405 for process 125
*Sep 2 16:22:24.019: TFTP: Finished flash0:jar75sip.9-2-3TH1-9.sbn, time 00:00:05 for process 125
*Sep 2 16:22:29.471: TFTP: Looking for cnu75.9-2-3TH1-9.sbn
*Sep 2 16:22:29.475: TFTP: Opened flash0:cnu75.9-2-3TH1-9.sbn, fd 10, size 576825 for process 125
*Sep 2 16:22:31.039: TFTP: Finished flash0:cnu75.9-2-3TH1-9.sbn, time 00:00:01 for process 125
*Sep 2 16:22:33.383: TFTP: Looking for apps75.9-2-3TH1-9.sbn
*Sep 2 16:22:33.383: TFTP: Opened flash0:apps75.9-2-3TH1-9.sbn, fd 10, size 4678486 for process 125
*Sep 2 16:22:46.047: TFTP: Finished flash0:apps75.9-2-3TH1-9.sbn, time 00:00:12 for process 125
*Sep 2 16:22:47.367: VOICE REGISTER POOL-1 has unregistered. Name:SEP64168DBB913F IP:192.168.15.6 DeviceType:Phone
*Sep 2 16:22:47.367: %SIPPHONE-6-UNREGISTER: VOICE REGISTER POOL-1 has unregistered. Name:SEP64168DBB913F IP:192.168.15.6 DeviceType:Phon
e
*Sep 2 16:22:58.315: TFTP: Looking for dsp75.9-2-3TH1-9.sbn
*Sep 2 16:22:58.315: TFTP: Opened flash0:dsp75.9-2-3TH1-9.sbn, fd 10, size 357547 for process 125
*Sep 2 16:22:59.283: TFTP: Finished flash0:dsp75.9-2-3TH1-9.sbn, time 00:00:00 for process 125
*Sep 2 16:23:01.195: TFTP: Looking for cvm75sip.9-2-3TH1-9.sbn
*Sep 2 16:23:01.195: TFTP: Opened flash0:cvm75sip.9-2-3TH1-9.sbn, fd 10, size 2663307 for process 125
*Sep 2 16:23:08.611: TFTP: Finished flash0:cvm75sip.9-2-3TH1-9.sbn, time 00:00:07 for process 125
*Sep 2 16:23:25.855: TFTP: Looking for term42.default.loads
*Sep 2 16:23:25.855: TFTP: Opened flash0:term42.default.loads, fd 10, size 678 for process 125
*Sep 2 16:23:25.863: TFTP: Finished flash0:term42.default.loads, time 00:00:00 for process 125
*Sep 2 16:23:27.175: TFTP: Looking for term42.default.loads
*Sep 2 16:23:27.175: TFTP: Opened flash0:term42.default.loads, fd 10, size 678 for process 125
*Sep 2 16:23:27.179: TFTP: Finished flash0:term42.default.loads, time 00:00:00 for process 125
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
router-voice#
*Sep 2 16:24:30.679: TFTP: Looking for CTLSEP64168DBB913F.tlv
*Sep 2 16:24:30.751: TFTP: Looking for ITLSEP64168DBB913F.tlv
*Sep 2 16:24:30.843: TFTP: Looking for ITLFile.tlv
*Sep 2 16:24:31.091: TFTP: Looking for SEP64168DBB913F.cnf.xml
*Sep 2 16:24:31.095: TFTP: Opened flash:/its/SEP64168DBB913F.cnf.xml, fd 10, size 5277 for process 125
*Sep 2 16:24:31.111: TFTP: Finished flash:/its/SEP64168DBB913F.cnf.xml, time 00:00:00 for process 125
*Sep 2 16:24:55.523: TFTP: Looking for SIP75.9-2-3S.loads
*Sep 2 16:24:55.523: TFTP: Opened flash0:SIP75.9-2-3S.loads, fd 10, size 650 for process 125
*Sep 2 16:24:55.527: TFTP: Finished flash0:SIP75.9-2-3S.loads, time 00:00:00 for process 125
*Sep 2 16:24:58.183: TFTP: Looking for jar75sip.9-2-3TH1-9.sbn
*Sep 2 16:24:58.183: TFTP: Opened flash0:jar75sip.9-2-3TH1-9.sbn, fd 10, size 1893405 for process 125
*Sep 2 16:25:03.559: TFTP: Finished flash0:jar75sip.9-2-3TH1-9.sbn, time 00:00:05 for process 125
*Sep 2 16:25:10.783: TFTP: Looking for cnu75.9-2-3TH1-9.sbn
*Sep 2 16:25:10.787: TFTP: Opened flash0:cnu75.9-2-3TH1-9.sbn, fd 10, size 576825 for process 125
*Sep 2 16:25:12.359: TFTP: Finished flash0:cnu75.9-2-3TH1-9.sbn, time 00:00:01 for process 125
*Sep 2 16:25:16.195: TFTP: Looking for apps75.9-2-3TH1-9.sbn
*Sep 2 16:25:16.195: TFTP: Opened flash0:apps75.9-2-3TH1-9.sbn, fd 10, size 4678486 for process 125
*Sep 2 16:25:29.035: TFTP: Finished flash0:apps75.9-2-3TH1-9.sbn, time 00:00:12 for process 125
*Sep 2 16:25:43.127: TFTP: Looking for dsp75.9-2-3TH1-9.sbn
*Sep 2 16:25:43.127: TFTP: Opened flash0:dsp75.9-2-3TH1-9.sbn, fd 10, size 357547 for process 125
*Sep 2 16:25:44.111: TFTP: Finished flash0:dsp75.9-2-3TH1-9.sbn, time 00:00:00 for process 125
*Sep 2 16:25:47.507: TFTP: Looking for cvm75sip.9-2-3TH1-9.sbn
*Sep 2 16:25:47.507: TFTP: Opened flash0:cvm75sip.9-2-3TH1-9.sbn, fd 10, size 2663307 for process 125
*Sep 2 16:25:54.751: TFTP: Finished flash0:cvm75sip.9-2-3TH1-9.sbn, time 00:00:07 for process 125
*Sep 2 16:26:54.331: TFTP: Looking for CTLSEP64168DBB913F.tlv
*Sep 2 16:26:55.223: TFTP: Looking for ITLSEP64168DBB913F.tlv
*Sep 2 16:26:55.347: TFTP: Looking for ITLFile.tlv
*Sep 2 16:26:55.703: TFTP: Looking for SEP64168DBB913F.cnf.xml
*Sep 2 16:26:55.707: TFTP: Opened flash:/its/SEP64168DBB913F.cnf.xml, fd 10, size 5277 for process 125
*Sep 2 16:26:55.723: TFTP: Finished flash:/its/SEP64168DBB913F.cnf.xml, time 00:00:00 for process 125
*Sep 2 16:27:06.923: TFTP: Looking for SIP_Italian_Italy/td-sip.jar
*Sep 2 16:27:08.235: TFTP: Looking for SIP_Italy/g3-tones.xml
*Sep 2 16:27:09.623: TFTP: Looking for softkeyDefault_kpml.xml
*Sep 2 16:27:09.623: TFTP: Opened flash:/its/softkeyDefault_kpml.xml, fd 10, size 4706 for process 125
*Sep 2 16:27:09.639: TFTP: Finished flash:/its/softkeyDefault_kpml.xml, time 00:00:00 for process 125
*Sep 2 16:27:13.251: VOICE REGISTER POOL-1 has registered. Name:SEP64168DBB913F IP:192.168.15.6 DeviceType:Phone
*Sep 2 16:27:13.251: %SIPPHONE-6-REGISTER: VOICE REGISTER POOL-1 has registered. Name:SEP64168DBB913F IP:192.168.15.6 DeviceType:Phone
0 Replies 0
