The installation has encountered a serious internal error. The system will be halted.
Nishad Ismail
Facing problem in fresh installation of Cisco unity connection in MCS7825 H3
Installation logs attached
Anas Abueideh
Level 9
Level 9
what is the unity connection version you are trying to install ?
it seems this unity connection version is not compatible with this hardware
Anas
don't forget to rate the helpful posts
Generally hardware issues are the problem.  If you are using a VM environment I would suggest using the .ova template to ensure everything is setup correctly.
Hi Anas,
 The CUC version is 8.5.1 ,Installing in MCS7825 -H3
I have gone through the compatibility matrix and its compactible .
 Nishad KI
Soumik
I have encountered similar problem today, I skip the 'Media Test' part and that worked.
