Time difference between PLM and CUCM
Nishad Ismail
We have PLM enable in the CUCM publisher ,We have enabled NTP in the Publisher .Publisher time is synced properly from the NTP and Getting proper Time ,The PLM is not a standalone server
In PLM time looks different time Zone timing ,The Time is correct but the time zone is different i guess
The CUCM Time Zone Correct and shows currect time
Can anyone have any clue on this issue ?
9 Replies 9
Aman Soi
where do u different timezone in PLM when PLM is co-resident with CUCM?
can u share the snapshot of show timezone config from Publisher and snapshot from PLM as well where u get this mismatch?
regds,
aman
Hi Aman,
The screenshot is attached .
The PLM its taking UTC time as current timing
The CUCM Taking Correct timezone  Asia/Riyadh
Hi Nlshad,
I never noticed this change.
But if u are using standalone PLM and can change time zone using CLI set timezone.
regds,
aman
We are not using standalone PLM .
The PLM using from CUCM publisher itself ..
I tried to look into any bug associated with this but could not find.
May be it is designed like this.
No more ideas .
regds,
aman
Hi Nlshad,
I checked where PLM is co-resident with CUCM .
The PLM shows UTC time zone only.PLM would work like this showing only UTC time zone.
In CUCM Pub, u would get both time zones i.e UTC and Asia /Riyadh or Asia Kolkata under utils ntp status.
regds,
aman
Hello NIshad,
This is not reproducible for me on 9.1(2), 10.0(1), and 10.5(2) with co-resident ELM/PLM.
Do I have it correct that this is last synchronization which shows up w/o timezone offset?
What is the exact CUCM version you are running?
You may check it from the CLI: show version active
Hi Nlshad,
I am  editing my last reply.
I checked up again and found that The PLM shows correct time zone along with time  instead of UTC after we do syncronisation on PLM .we have co-resident PLM.
we are using CUCM version 10.5.1.10000-7.
Apologizes for wrong info.
Hi Mateusz,
If you could help us in resolving in issue, would be great.
regds,
aman
Hi Mateusz,
Find the output of "show status,Utils NTP status,show version active ,shop timezone config" and screenshot of the PLM and CUCM show system
Now got really confusing ...
GUI shows UTC time in CUCM and CLI shows different
admin:show status
Host Name          : ucmpub01
Date               : Wed May 20, 2015 12:36:06
Time Zone          : Arabia Standard Time (Asia/Riyadh)
Locale             : en_US.UTF-8
Product Ver        : 10.5.2.10000-5
Unified OS Version : 6.0.0.0-2
Uptime:
 12:36:07 up 10 days, 12:18,  1 user,  load average: 0.24, 0.20, 0.18
CPU Idle:   85.13%  System:   02.05%    User:   12.31%
  IOWAIT:   00.00%     IRQ:   00.00%    Soft:   00.51%
Memory Total:        5994172K
        Free:         117552K
        Used:        5876620K
      Cached:        2011688K
      Shared:              0K
     Buffers:         129000K
                        Total            Free            Used
Disk/active         20304764K        7478776K       12619704K (63%)
Disk/inactive       20304764K       19097276K         176064K (1%)
Disk/logging        70646184K       44972492K       22085036K (33%)
admin:util
admin:utils ntp status
ntpd (pid 8491) is running...
     remote           refid      st t when poll reach   delay   offset  jitter
*10.10.38.28     192.168.6.200    3 u  803 1024  377    0.849    0.645   0.427
synchronised to NTP server (10.10.38.28) at stratum 4
   time correct to within 70 ms
   polling server every 1024 s
Current time in UTC is : Wed May 20 09:36:33 UTC 2015
Current time in Asia/Riyadh is : Wed May 20 12:36:33 AST 2015
admin:
admin:
admin:
admin:show version active
Active Master Version: 10.5.2.10000-5
Active Version Installed Software Options:
cmterm-devicepack10.5.2.12014-1.cop
ciscocm.migrate-export-v1.12.cop
ciscocm.ucmap_platformconfig.cop
cmterm-dx650.10-1-2-33.cop
admin:
admin:show timezone config
Current timezone: Arabia Standard Time (Asia/Riyadh)
Timezone version: 2014f
admin:
